AUDIO-TECHNICA ATH-ADX3000 Open-Back Dynamic Headphone
New
The Audio-Technica ATH-ADX3000 are high-end headphones hand-assembled in Japan and featuring a 58mm diameter dynamic transducer. Its open design has been thought out for a natural rendering thanks to optimized air circulation.
By buying this product you get 99 loyalty points
Reference : 20770
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 10-06-2025.
Audio-Technica ATH-ADX3000 Open-Back Dynamic Headphone Ø58mm 50 ohm 98dB 5Hz-45kHz
Photo of AUDIO-TECHNICA ATH-ADX3000 headphones
The Audio-Technica ATH-ADX3000 are high-end headphones hand-assembled in Japan and featuring a 58mm diameter dynamic transducer. Its open design has been thought out for a natural rendering thanks to optimized air circulation. These headphones offer full-range reproduction with natural bass and reduced distortion. It features a detachable cable with A2DC connectors and 6.35mm jack termination for a high level of compatibility. Its 50 ohm impedance and 98dB sensitivity make it easily driven, and will delight many listeners. Moreover, its weight of just 257g makes it an extremely comfortable pair of headphones.
AUDIO-TECHNICA ATH-ADX3000 highlights
Audio-Technica ATH-ADX3000: 58mm transducer
The transducer of the Audio-Technica ATH-ADX3000 headphones combines a tungsten-coated diaphragm, voice coil, baffle and magnet in a single element to avoid any form of unwanted vibration. Furthermore, the proprietary Core Mount technique places the transducer in an optimal position to facilitate airflow and reduce distortion. This design is inspired by the brand's ATH-ADX5000 headphones.
The transducer of the AUDIO-TECHNICA ATH-ADX3000
Photo of AUDIO-TECHNICA ATH-ADX3000 headphones in storage box
Audio-Technica ATH-ADX3000: Comfortable, easy-to-match headphones
The ATH-ADX3000 features a magnesium alloy frame for a rigid, slim and lightweight structure. Weighing just 257g, they are extremely comfortable to wear. And the velvet ear cushions ensure pleasant skin contact. As for connectivity, there's a detachable cable with A2DC connectors and 6.35mm jack termination for easy pairing with most headphone amplifiers on the market.
Product typeHeadphones
Headphone typeOpen-Back
Dynamic
Transducer diameterØ53mm
Frequency response5Hz-45kHz
Max. input power700mW
Sensitivity98dB/mW
Impedance50 ohm
Detachable cable
Cable length3m
Headphone connectorA2DC
Cable terminationJack 6.35mm
Weight257g
Package1x Audio-Technica ATH-ADX3000 headphones
1x Detachable cable A2DC connector to 6.35mm jack termination
1x Storage box
Impedance (Ω)50
Efficiency / Sensitivity (dB)98.0
Lowest frequency (Hz)5
Highest frequency (Hz)45000
WirelessNo
Headphone / Earphone connectorA2DC
AUDIO-TECHNICA ATH-ADX3000 Open-Back Dynamic Headphone Ø58mm 50 ohm 98dB 5Hz-45kHz
The Audio-Technica ATH-ADX3000 are high-end headphones hand-assembled in Japan and featuring a 58mm diameter dynamic transducer. Its open design...
