By buying this product you get 99 loyalty points
The Audio-Technica ATH-ADX3000 are high-end headphones hand-assembled in Japan and featuring a 58mm diameter dynamic transducer. Its open design has been thought out for a natural rendering thanks to optimized air circulation. These headphones offer full-range reproduction with natural bass and reduced distortion. It features a detachable cable with A2DC connectors and 6.35mm jack termination for a high level of compatibility. Its 50 ohm impedance and 98dB sensitivity make it easily driven, and will delight many listeners. Moreover, its weight of just 257g makes it an extremely comfortable pair of headphones.
The transducer of the Audio-Technica ATH-ADX3000 headphones combines a tungsten-coated diaphragm, voice coil, baffle and magnet in a single element to avoid any form of unwanted vibration. Furthermore, the proprietary Core Mount technique places the transducer in an optimal position to facilitate airflow and reduce distortion. This design is inspired by the brand's ATH-ADX5000 headphones.
The ATH-ADX3000 features a magnesium alloy frame for a rigid, slim and lightweight structure. Weighing just 257g, they are extremely comfortable to wear. And the velvet ear cushions ensure pleasant skin contact. As for connectivity, there's a detachable cable with A2DC connectors and 6.35mm jack termination for easy pairing with most headphone amplifiers on the market.
Product type | Headphones |
Headphone type | Open-Back Dynamic |
Transducer diameter | Ø53mm |
Frequency response | 5Hz-45kHz |
Max. input power | 700mW |
Sensitivity | 98dB/mW |
Impedance | 50 ohm |
Detachable cable | |
Cable length | 3m |
Headphone connector | A2DC |
Cable termination | Jack 6.35mm |
Weight | 257g |
Color | Black |
Package | 1x Audio-Technica ATH-ADX3000 headphones 1x Detachable cable A2DC connector to 6.35mm jack termination 1x Storage box |
Color | Black |
Impedance (Ω) | 50 |
Efficiency / Sensitivity (dB) | 98.0 |
Lowest frequency (Hz) | 5 |
Highest frequency (Hz) | 45000 |
Wireless | No |
Headphone / Earphone connector | A2DC |
