AUNE AC45 Headphones
The Aune AC45 is an open-back clip-on dynamic headphone featuring 40mm bio-fiber composite diaphragms. It delivers a wide soundstage and immersive bass for a highly enjoyable listening experience. Its open design provides an airy and clear presentation. The clip-on system remains extremely comfortable compared to traditional headband headphones; the hook features semi-memory shaping and each earpiece weighs only 35g, making it ideal for long listening sessions. The AC45 comes with a detachable CIEM 0.78mm cable with interchangeable terminations (3.5mm jack / 4.4mm balanced jack) for excellent compatibility.
Reference : 21533
139,00 €tax incl.
115,83 € tax excl.
Aune AC45 Open-Back Clip-On Dynamic Headphones 18 ohm 112dB 15Hz-40kHz
Photo of the AUNE AC45
Aune AC45: An audiophile structure
Biofiber composite diaphragm (W-shape)
The 40mm W-shaped diaphragm increases the vibration surface by approximately 70% compared to conventional headphones. Lightweight yet rigid, it delivers clear and airy highs. The linear surround system improves bass performance, producing immersive low frequencies.
Independent linear surround system
The linear surround system enhances bass performance, delivering immersive low frequencies. It reinforces low-mid presence and ensures bass remains solid and full, even within an open soundstage.
Highly dynamic symmetrical motor
It provides sufficient power to drive the diaphragm. Even in complex and highly dynamic sound environments, it maintains stable reproduction and outstanding resolution. Every impact is crisp and precise, and every detail is vividly reproduced.
Aune AC45: Open clip-on design
The open design allows sound to diffuse naturally, creating a spacious and immersive soundstage with realistic imaging. Compared to in-ear monitors or closed-back headphones, the AC45 offers high transparency, lightness, and authenticity in sound reproduction.
AUNE AC45 open clip-on design Aune AC45 measurements
Aune AC45: Detachable cable with interchangeable termination
The OFC copper Litz cable ensures clean signal transmission. Its interchangeable 3.5mm jack / 4.4mm balanced termination makes it compatible with a wide range of devices.
AUNE AC45 detachable cable with interchangeable termination
Technical specifications
Product typeHeadphones
Headphone typeOpen clip-on
DriverDynamic
Nominal impedance18 ohm
Sensitivity112dB @1kHz
Frequency response15Hz-40kHz
THD< 0.3% @1kHz
Detachable cable
Cable structureLitz
Conductor materialOFC copper
Earphone connectorCIEM 0.78mm
Interchangeable cable terminationSingle-ended 3.5mm jack
Balanced 4.4mm jack
Cable length1.25m
Dimensions135 x 77 x 61mm
Gross weight260g
Net weight35g/earpiece
Package contents1x Aune AC45
1x CIEM 0.78mm cable with interchangeable termination
1x 3.5mm jack termination
1x 4.4mm balanced jack termination
1x Storage pouch
Impedance (Ω)18
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)15
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
AUNE AC45 Open Back Clip-On Dynamic Headphones 18 Ohms 112dB 15Hz-40kHz
The Aune AC45 is an open-back clip-on dynamic headphone featuring 40mm bio-fiber composite diaphragms. It delivers a wide soundstage and immersive...
