HARMONICDYNE BAROQUE Headphones
The HarmonicDyne Baroque is an open headphone featuring a 60 mm dynamic transducer, designed to deliver signal reproduction with high transient precision and controlled distortion. It leverages a ceramic-metal composite diaphragm coupled with a CNC-machined aluminium acoustic chamber to control resonances and stabilize response across the full spectrum.
By buying this product you get 68 loyalty points
Reference : 22230
689,67 €tax incl.
574,72 € tax excl.
Shipping date: 18-11-2026.
HarmonicDyne Baroque Open Dynamic Headphones 64 Ohms 107dB 10Hz-50kHz
HarmonicDyne Baroque : Front view
Intended for seated listening, it combines rigid acoustic architecture with ergonomic design, enabling coherent reproduction and wearing comfort across extended sessions.
HarmonicDyne Baroque: Ceramic-metal composite transducer
The HarmonicDyne Baroque integrates a 60 mm dynamic transducer relying on a ceramic-metal composite diaphragm, whose high stiffness limits deformation during vibration, thereby reducing distortion in the upper spectrum. This structure extends to a more reactive metal substrate, accelerating diaphragm movement to improve transient precision, resulting in detailed and structured micro-information restitution.
HarmonicDyne Baroque: Aluminium acoustic chamber
The acoustic chamber, realized in aerospace-grade aluminium alloy and machined with precision, ensures high mechanical rigidity that attenuates internal parasitic resonances. This vibration control translates to reduced coloration in midrange and bass frequencies, while machining precision enables fine acoustic tuning, allowing coherent and readable soundstage.
HarmonicDyne Baroque: Ergonomic headband
The headband adopts a stainless steel structure designed to distribute pressure uniformly across the skull, limiting pressure points during extended listening. This approach extends to ergonomic geometry that stabilizes headphone positioning while maintaining controlled weight, ensuring stable and sustained wear even across lengthy sessions.
HarmonicDyne Baroque: Breathable ear pads
The ear pads combine a protein leather covering with a breathable mesh structure, balancing mechanical resistance and air circulation. This design promotes heat evacuation while maintaining soft skin contact, while their density contributes to improved sonic clarity and relative isolation, ensuring sustained comfort and controlled listening over time.
Technical specifications
Product typeHeadphones
Headphone typeOpen circumaural
Speaker typeDynamic
Impedance64Ω @1kHz
Sensitivity109dB/Vrms @1kHz
Total harmonic distortion (THD)≤0.2% @1kHz
Frequency response10Hz-50kHz
Dimensions230 × 200 × 100mm
Package1x HarmonicDyne Baroque
1x Headphone cable 3.5mm jack to 2x 3.5mm jack
1x Headphone cable 4.4mm jack to 2x 3.5mm jack
1x Headphone carrying pouch
Impedance (Ω)64
Efficiency / Sensitivity (dB)107
Lowest frequency (Hz)10
Highest frequency (Hz)50000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
HARMONICDYNE BAROQUE Open Dynamic Headphones 64 Ohms 107dB 10Hz-50kHz
The HarmonicDyne Baroque is an open headphone featuring a 60 mm dynamic transducer, designed to deliver signal reproduction with high transient...
