By buying this product you get 36 loyalty points
Aune unveils here the MKII version of its AR5000 headphones. It is also an open-back headphone featuring a dynamic MLD ("Multi-Layer Distributed") driver measuring no less than Ø50mm. However, Aune has decided to improve certain aspects such as the dynamic driver and the overall acoustic architecture of the headphones for a better frequency response with extended and detailed highs as well as deeper bass. The MKII version retains a high-angle acoustic structure for clear and detailed sound reproduction. Its 28-ohm impedance and 112dB sensitivity make it easy to drive. In addition, it benefits from a detachable cable with interchangeable termination, allowing a high level of compatibility with various headphone amplifiers.
The Ø50mm dynamic driver with MLD diaphragm of the Aune AR5000 MKII offers a balance between rigidity and damping, significantly reducing distortion across the entire frequency response range. The result is transparency and a high level of detail. Its optimization through new materials and surface treatments enables extended high-frequency performance.
A new airflow management system and a new magnetic circuit structure provide better linearity and deeper bass.
The Aune AR5000 MKII features a high-end detachable cable with OFC copper conductors and a Litz wire structure. In addition, its interchangeable 6.35mm jack, 3.5mm jack, and balanced 4.4mm jack terminations provide a high level of compatibility.
Technical Specifications
| Specifications | |
| Product Type | Headphones |
| Headphone Type | Open-Back |
| Driver | Dynamic with MLD technology |
| Frequency Response | 28 ohms |
| Nominal Impedance | 28 ohms |
| Sensitivity | 112dB SPL @ 1kHz/1Vrms |
| THD | <0.03% @ 1kHz |
| Detachable Cable | |
| Headphone Connectors | 2x 3.5mm Jack |
| Interchangeable Termination | 1x 3.5mm Jack 1x 6.35mm Jack 1x Balanced 4.4mm Jack |
| Cable Length | 1.5m |
| General | |
| Dimensions | 224 x 238 x 122mm |
| Weight | 365g |
| Package Contents | 1x Aune AR5000 MKII 1x 2x 3.5mm Jack Cable with Interchangeable Termination 1x 3.5mm Jack Termination 1x 6.35mm Jack Termination 1x Balanced 4.4mm Jack Termination |
| Color | Champagne |
| Impedance (Ω) | 28 |
| Efficiency / Sensitivity (dB) | 112.0 |
| Lowest frequency (Hz) | 5 |
| Highest frequency (Hz) | 43500 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Cable termination | Jack 6.35mm |
| Cable termination | Jack 4.4mm |
| Headphone / Earphone connector | Jack 3.5mm |
