DAN CLARK AEON CORE Headphone
The Dan Clark Audio Aeon Core, direct successor to the Aeon 2, is a closed-back planar magnetic headphone designed to deliver coherent and controlled reproduction across varied listening environments. It operates at 17 ohms impedance paired with a sensitivity of 94 dB/mW, relying on a next-generation planar transducer featuring an optimised diaphragm and V-Planar technology to reduce distortion (< 0.1% at 80 dB) while stabilising frequency response. This architecture improves overall efficiency while maintaining tonal linearity and usable dynamics across a wide operating range.
By buying this product you get 99 loyalty points
Reference : 22147
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 17-11-2026.
Dan Clark Audio Aeon Core Closed-Back Planar Magnetic Headphone 17 Ohm 94dB
Dan Clark Audio Aeon Core : Front view
The Dan Clark Audio Aeon Core, direct successor to the Aeon 2, is a closed-back planar magnetic headphone designed to deliver coherent and controlled reproduction across varied listening environments. It operates at 17 ohms impedance paired with a sensitivity of 94dB/mW, relying on a next-generation planar transducer featuring an optimised diaphragm and V-Planar technology to reduce distortion (< 0.1% at 80dB) while stabilising frequency response. This architecture improves overall efficiency while maintaining tonal linearity and usable dynamics across a wide operating range.
Dan Clark Audio Aeon Core Review by Audio Science Review
" Dan Clark continues to advance the state of the art in science based development of headphones. The entry ticket up to now though has been rather steep. That changes with the CORE. [...] And at any rate, it is much more affordable than their top of line. It also brings looks and style that I am proud to wear on my head! "
Product typeHeadphone
Headphone typeClosed-back circumaural
Driver typePlanar magnetic
Headphone materialAluminium, titanium and wood
Sensitivity94dB
Impedance17Ω
Headphone connectorHirose
Cable termination4.4mm
Cable length2m
Total harmonic distortion (THD)< 0.1% @80dB
Weight440g
Package1x Dan Clark Audio Aeon Core
1x Dual Hirose to 4.4mm jack cable
Impedance (Ω)17
Efficiency / Sensitivity (dB)94.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
WirelessNo
Cable terminationJack 4.4mm
Headphone / Earphone connectorHirose
DAN CLARK AEON CORE Headphone Closed-Back Planar Magnetic 17 Ohm 94dB
The Dan Clark Audio Aeon Core, direct successor to the Aeon 2, is a closed-back planar magnetic headphone designed to deliver coherent and...
