FIIO FT7 Headphones
The FiiO FT7 is a high-end open-back planar magnetic headphone designed for exceptional sound reproduction. It is based on a large 106mm planar driver, one of the biggest in its category, combined with an ultra-thin 1µm PET diaphragm. This diaphragm features a patented multi-layer coating made of 24K gold and pure silver, optimizing both conductivity and musicality.
By buying this product you get 74 loyalty points
Reference : 21641
749,00 €tax incl.
624,17 € tax excl.
FiiO FT7 Open-Back Over-Ear Planar Magnetic Headphones 25 Ohm 94dB 5Hz-40kHz
Photo of the FIIO FT7
The FT7 offers an extended frequency response from 5Hz to 40kHz, ensuring faithful reproduction across the entire spectrum, from deep bass to ultra-high frequencies. It comes with a 6N OCC monocrystalline copper cable, treated with cryogenic processing at -192°C, with PFA insulation ensuring excellent signal transmission.
In terms of connectivity, the headphone is equipped with a 4.4mm balanced connector, along with adapters to 4-pin XLR and 6.35mm jack, ensuring wide compatibility with both portable and desktop audio systems. Its design incorporates premium materials such as carbon fiber and natural wood (zebrawood), for a controlled weight of around 427g, combining durability, comfort and acoustic performance.
Accessories of the FIIO FT7
FiiO FT7 : An ultra high-precision planar diaphragm
The FiiO FT7 uses a latest-generation planar diaphragm based on an ultra-thin PET substrate of only 1µm, enabling exceptional responsiveness and extremely detailed micro-information reproduction.
This diaphragm is manufactured using an advanced 28nm-grade deposition process, ensuring a homogeneous and durable structure. FiiO applies a patented multi-layer coating combining 24K gold and pure silver, each material bringing its own properties :
  • Silver promotes excellent conductivity and fast, precise reproduction
  • Gold provides harmonic richness and natural sound rendering
This combination results in a sound that is both analytical and musical, with a significant reduction in distortion and excellent long-term stability.
FIIO FT7 : an ultra high-precision planar diaphragm
FiiO FT7 : A powerful and optimized magnet array
The FT7 integrates an advanced magnetic system based on a dual-sided push-pull architecture, placing magnets on both sides of the diaphragm for optimal control of its movement.
This system relies on high-performance N52 neodymium magnets, with a total of 18 magnets (9 on each side), generating a magnetic flux of up to 1.5 Tesla. This power ensures excellent dynamics, tight bass and fast transient response.
The magnetic structure also benefits from a patented uniform magnetic field design, with optimized magnet shapes allowing :
  • Even force distribution across the entire diaphragm surface
  • Reduced deformation (breakup)
  • Lower distortion
  • Overall improved sound accuracy
FIIO FT7 : a powerful and optimized magnet array
FiiO FT7 : A high-purity audiophile cable with cryogenic treatment
The FiiO FT7 comes with a premium cable designed to preserve audio signal integrity. It uses 6N OCC monocrystalline copper (99.99998%), ensuring exceptional conductivity and extremely low signal loss.
This cable undergoes cryogenic treatment at -192°C for 7 days, improving the crystal structure of the copper, reducing internal stress and optimizing electron flow.
Insulation is provided by PFA (Perfluoroalkoxy), characterized by a low dielectric constant (2.1), which reduces losses and improves signal stability. This design contributes to a more natural sound reproduction, with rich mids and better-defined bass.
FIIO FT7 : a high-purity audiophile cable with cryogenic treatment
FIIO FT7 : a versatile interchangeable connectivity system
FiiO FT7 : a versatile interchangeable connectivity system
The FT7 adopts a modular connectivity solution with a detachable cable, allowing great flexibility of use. It comes equipped with a 4.4mm balanced connector, ideal for optimal channel separation and improved signal quality.
To adapt to different equipment, FiiO provides two adapters :
  • 4.4mm to 4-pin XLR adapter for balanced desktop amplifiers
  • 4.4mm to 6.35mm jack adapter for standard use
This system ensures wide compatibility with audio sources, whether audiophile players, DAC/amplifiers or Hi-Fi systems, while maintaining a high level of performance.
Technical specifications
Product typeHeadphones
Headphone typeOpen-back over-ear
DriverPlanar magnetic
Diaphragm diameter106mm
Impedance25 ohms ±15%
Sensitivity94dB/mW @ 1kHz
110dB/Vrms @ 1kHz
Frequency response5Hz-40kHz
Detachable cable
Cable conductor material6N OCC monocrystalline copper (99.99998%)
Headphone connectors2x 3.5mm TS jack
Cable termination1x 4.4mm jack
Length3m
Earpad pressure4.2N±0.3N
Weight427g
ColorWood
Package contents1x FiiO FT7
1x Detachable cable 2x 3.5mm jack to 4.4mm termination
1x 4.4mm to 6.35mm jack adapter
1x 4.4mm to 4-pin XLR adapter
1x Leather earpads pair
1x Fabric earpads pair
1x Storage pouch
ColorWood
Impedance (Ω)25
Efficiency / Sensitivity (dB)94.0
Lowest frequency (Hz)5
Highest frequency (Hz)40000
WirelessNo
Cable terminationXLR 4-pin
Cable terminationJack 6.35mm
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
FIIO FT7 Headphones Open-Back Over-Ear Planar Magnetic 25 Ohms 94dB 5Hz–40 kHz
The FiiO FT7 is a high-end open-back planar magnetic headphone designed for exceptional sound reproduction. It is based on a large 106mm planar...
