HIFIMAN ARYA ORGANIC Headphones
The HiFiMAN Arya Organic is an open-back planar magnetic headphone designed for high-fidelity reproduction, utilising an ultra-lightweight nanometric diaphragm to reduce inertia and stabilise signal response. It covers an extended frequency range from 8Hz to 65kHz, thanks to its magnetic circuit and Stealth Magnets, thereby maintaining consistent reproduction across the entire spectrum whilst minimising diffraction-related distortions.
By buying this product you get 78 loyalty points
Reference : 21831
789,00 €tax incl.
657,50 € tax excl.
HiFiMAN ARYA ORGANIC Open-back Circumaural Headphones Planar Magnetic 16 Ohm 8Hz-65kHz
Photo of the HIFIMAN Arya Organic
This headphone combines an open-back architecture with wave propagation control, enabling the soundstage to be shaped and improving instruments separation. This design, combined with a 16Ω impedance and adaptable connectivity, makes it easy to integrate with various amplifier setups, whilst ensuring stable performance during extended listening sessions.
HiFiMAN Arya Organic: Design and performance
The Arya Organic features a planar magnetic driver whose nanometric diaphragm, characterised by its very low mass, reduces inertial effects, thereby limiting distortion during rapid signal changes. This design is based on a magnetic circuit that homogenises the distribution of the magnetic flux around the diaphragm, thereby ensuring consistent performance across the entire frequency range.
In line with this, Stealth Magnet drivers feature an optimised design that facilitates airflow through the transducer, thereby reducing diffraction and internal disturbances. The frequency response, ranging from 8Hz to 65kHz, enables a wide-ranging reproduction, covering both low and high frequencies, without any break in the sound.
Image showing the structure of the Arya Organic membrane
Photo of the Arya Organic earpiece and its open grille
HiFiMAN Arya Organic: Sound reproduction and sound quality
The Arya Organic’s open-back design minimises the build-up of internal pressure, thereby reducing unwanted resonance and promoting better ventilation of the sound. This approach is further enhanced by the Window Shade system, which controls wave propagation at the rear of the transducer to manage reflections and limit unwanted vibrations.
These design choices result in a clearer soundstage, with better separation of sound sources and more precise spatial localisation.
HiFiMAN Arya Organic: Interface and ergonomics
With an impedance of 16Ω and a sensitivity of 94dB, the Arya Organic pairs easily with a wide variety of sources. This configuration ensures seamless integration with both dedicated DACs/amplifiers and more compact sources, while maintaining consistent sound reproduction.
This versatility extends to its connectivity, which features two 3.5mm jacks. The headphones come with a 1.5-meter detachable cable featuring copper conductors and dual 3.5mm jack to 6.35mm jack. Additionally, the CNC-machined metal frame combined with asymmetrical ear cushions optimizes weight distribution, ensuring consistent comfort during extended use.
Photo of the Arya Organic and its connectors
Product typeHeadphones
Type of headphonesOpen-back circumaural
TransducersPlanar magnetic
Impedance16Ω
Sensitivity94dB
Frequency response8Hz-65kHz
Detachable cableYes
Headphone jack2x 3.5mm Jack
Weight440g
Package1x Arya Organic
1x Dual 3.5mm Jack to 6.35mm Jack cable
Impedance (Ω)16
Efficiency / Sensitivity (dB)94.0
Lowest frequency (Hz)8
Highest frequency (Hz)65000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
HIFIMAN ARYA ORGANIC Headphones Open Back Circumaural Planar Magnetic 16 Ohm 8Hz-65kHz
The HiFiMAN Arya Organic is an open-back planar magnetic headphone designed for high-fidelity reproduction, utilising an ultra-lightweight...
