MEZE 99 CLASSICS 2nd GEN Headphones
More than 10 years after the release of the Meze Audio 99 Classics, the brand unveils the second generation of this iconic model that has left its mark on the world of headphones. This second generation retains the essence of what made the first version so successful, but with numerous improvements.
By buying this product you get 34 loyalty points
Reference : 21246
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 24-11-2026.
Meze 99 Classics 2nd Gen Closed-Back Dynamic Headphones 16 Ohm 103dB 15Hz-25kHz Walnut
Photo du MEZE 99 CLASSICS 2nd GEN
More than 10 years after the release of the Meze Audio 99 Classics, the brand unveils the second generation of this iconic model that has left its mark on the world of headphones. This second generation retains the essence of what made the first version so successful, but with numerous improvements. In particular, it retains its elegant aesthetic thanks to the high-quality materials used in its construction: walnut shell, vegan leather headband, manganese and zinc mechanical parts, etc. In terms of technical specifications, its 16-ohm impedance and 103db sensitivity make it easy to drive. It also has a slightly extended frequency response of 15Hz to 25kHz for rich and detailed sound reproduction. The overall sound reproduction is described as neutral and balanced and will suit many profiles, such as music lovers, content creators, and musicians. It comes with a high-end cable with a 3.5mm jack and OFC conductors, as well as a 6.35mm jack adapter and a USB-C adapter with built-in DAC to suit almost any situation.
Mises en situation du MEZE 99 CLASSICS 2nd GEN
Meze 99 Classics
Tuning
Balanced, neutral
Warm, V-shaped
Ear Cup Internal Volume
Increased
Classic
Acoustic Sealing
Improved sealing at all key junctions (Baffle-cup, PCB-jack shell, jack shell-cup, ear pad-baffle)
Classic
Bass Port
Present - integrated into the 3.5 mm jack shell
Not present
Baffle Architecture
Re-engineered - more open grille and streamlined structural beams
Classic
Ear Pads
Using clip-in mechanism, reshaped to adjust the front cavity volume
Using stretch-skirt attachment
Sound Technicalities
Improved separation, imaging, and soundstage
Classic
Input Socket
Enlarged to 7 millimeters in diameter, ensuring compatibility with a wider range of cables
Narrow
Stock cable(s)
1.8 m dual-twisted, Kevlar-wrapped soft flex PVC, OFC conductor, 3.5 mm jack
1.2 m thread Kevlar with Mic and remote, OFC conductor & 3 m thread Kevlar, OFC conductor
Adapters
USB-C DAC/AMP dongle, 6.3 mm gold-plated jack adapter
Airplane adapter, 6.3 mm gold- plated jack adapter
Meze 99 Classics 2nd Gen overview
MEZE 99 CLASSICS 2nd GEN overview
1Earpad
2Earpad carrier
3Gasket
4Dust protector
5ABS baffle plate
6Driver: PEEK Surround / Torus / PEEK Dome / Neodymium Magnet System
7Acoustic filters
8Gasket
9Walnut shell
103.5mm jack socket
11Gasket
12Acoustic filter
13Jack shell
14Swivel system
15Swivel cap (trumpet)
Product typeHeadphones
Headphones typeClosed-back circumaural dynamic headphones
Driver diameterØ40mm
Impedance16 ohm
Sensitivity103dB SPL/mW @ 1kHz
Frequency response15Hz-25kHz
THD< 0.1% @ 1kHz
Shell materialWalnut wood
Headphones connectors2x 3.5mm TS jack
Detachable cable
Cable conductor materialsCuivre OFC
Cable terminaisonStereo 3.5mm jack
Adjustable headband
Detachable ear pads
Tone adjustmentAcoustic absorbers for a warmer signature closer to 1st Gen
Weight290g
Package1x Meze 99 Classics 2nd Gen
1x OFC Kevlar cable with 3.5mm jack connector
1x EVA storage case
1x Cable pouch
1x 6.35mm jack adapter
1x 3.5mm jack to USB-C adapter (DAC dongle)
ColorWalnut
Impedance (Ω)16
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)15
Highest frequency (Hz)25000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
MEZE 99 CLASSICS 2nd GEN Closed-Back Dynamic Headphones 16 Ohm 103dB 15Hz-25kHz Walnut
More than 10 years after the release of the Meze Audio 99 Classics, the brand unveils the second generation of this iconic model that has left its...
