LINDY LH700XW Wireless Headphone Active Noise Cancellation ANC Bluetooth 5.0 aptX 20Hz-20kHz
The Lindy LH700XW headphones offer excellent sound quality, combined with a Bluetooth 5.0 wireless connection supporting the high-resolution aptX transmission codec. It also features hybrid noise-cancellation technology that guarantees 98% reduction in external ambient noise, thanks to both feedforward and internal noise-sensing microphones. This technology allows a pleasant listening, even in noisy environments.
Reference : 15861
129,00 €tax incl.
107,50 € tax excl.
Lindy LH700XW
Lindy LH700XW Casque Audio Sans-Fil Réduction de Bruit Active ANC Bluetooth 5.0 aptX 20Hz-20kHz
The LH700XW's control buttons allow easy and transparent management of playback and volume level. The on-board microphone can also be used to make phone calls, and the controls can be used to manage the call in progress. Two devices can be paired with the headphones simultaneously.
The built-in battery can be fully recharged in just 3 to 4 hours, providing up to 50 hours of wireless use. A 3.5mm jack cable is also provided for a wired connection, with which the reduction technology also works.
Finally, the headphone also offers a very good comfort thanks to thick leatherette pads, a reduced weight and an adjustable headband.
Product typeHeadphone
Headphone designCircum-aural
Speaker drivers40mm
ConnectivityInput : Jack 3.5mm
Power connect : Micro USB
Active Noise Cancellation (ANC)98% reduction of low frequency noise
Bluetooth version5.0
Bluetooth chipQCC3005
BatteryLithium
Battery lifeANC only : 92h
Wireless only : 50h
ANC + Wireless : 35h
ImpedancePassive mode : 32Ω
ANC mode : 100Ω
Sensitivity (1mW @ 1kHz ±3dB)104dB ±3dB
Frequency response20Hz-20kHz
THDPassive mode : < 1% @ 1kHz
Active mode : < 1% @ 1kHz
Hands-free calling function
Dual pairing
Dimensions160 x 80 x 185mm
Shell materialPlastic
Weight291g
Operating temperature-10°C / 35°C
Storage temperature-10°C / 35°C
Relative humidity0% - 30% RH (no condensation)
CertificationsCE, RoHS, REACH, California Proposition 65
Package1x Lindy LH700XW
1x Jack 3.5mm 1m cable
1x USB-A to Micro USB 0.3m cable
1x Jack 6.35mm adapter
1x Airplane adapter
1x Hard carrying case
Impedance (Ω)100
Impedance (Ω)32
Efficiency / Sensitivity (dB)104.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorWireless (Bluetooth)
Headphone / Earphone connectorJack 3.5mm
un bon casque
Je l'utilise dans les transports.
Le casque est bien construit. L'isolation passive est suffisante sans recourir à la réduction électronique la plupart du temps. Mais parfois c'est bienvenu pour avoir un peu de calme. Evidement l'audio est filtré également.
Le casque isole bien de l'extérieur en plaquant efficacement les oreillettes, j'ai donc rapidement chaud et je crains que le casque ne soit pas très utilisable en été.
L'étui de transport est bien pratique. Le casque n'a pas de logo voyant et c'est très bien comme cela.
La qualité audio est bonne mais pas excellente pour une oreille audiophile. Il n'y a pas de résonnances particulières ou d'équalisation désagréable.
Pour finir, je trouve le prix est un peu élevé.
This review has been posted for LINDY LH700XW Wireless Headphone Active Noise Cancellation ANC Bluetooth 5.0 aptX 20Hz-20kHz
The Lindy LH700XW headphones offer excellent sound quality, combined with a Bluetooth 5.0 wireless connection supporting the high-resolution aptX...
