MEZE AUDIO 105 AER Headphones
-25%
Meze Audio 105 AER headphones are dynamic circumaural open-air headphones featuring a high-performance, long-lasting audiophile design. In fact, the 105 AER's design is based on top-of-the-range components and materials, delivering exceptional sound quality. It features two dynamic dual-diaphragm transducers, each no less than 50mm in diameter, for extended frequency response from 5Hz-30kHz. In addition, its enhanced sensitivity of 112dB and 42-ohm impedance guarantee a high level of compatibility with all types of Hi-Fi equipment.
Reduced price!
Reference : 20412
Limited time offer:
399,00 €tax incl.
-25%
299,00 €tax incl.
249,17 € tax excl.
Meze Audio 105 AER Open-Back Dynamic Circumaural Headphones 112dB 42 Ohm 5Hz-30kHz
Photo du Meze Audio 105 AER
The Meze Audio 105 AER are dynamic circumaural open-back headphones designed to deliver outstanding audiophile performance in a durable structure. In fact, the 105 AER's design is based on top-of-the-range components and materials, delivering exceptional sound quality. It incorporates two dynamic double-diaphragm transducers, each no less than 50mm in diameter, for an extended frequency response of 5Hz-30kHz. In addition, its 112dB sensitivity and 42-ohm impedance guarantee a high level of compatibility with all types of Hi-Fi equipment.
In terms of sound, the 105 AER stands out for its deep but controlled bass, natural midrange and precise, detailed highs, offering a balanced, versatile sound signature. A detachable 3.5mm jack cable and 6.35mm jack adapter are included. A little brother to the Meze Audio 109 PRO, it represents a more affordable but no less high-performance alternative.
Vue éclaté du casque et photo du casque porté
Meze Audio 105 AER: audiophile sound reproduction
Thanks to its dynamic Ø50mm transducers, the 105 AER is capable of reproducing immersive bass and detailed highs for a perfectly balanced sound experience. he open design of the headphones broadens the soundstage, offering rich reproduction where every instrument and every voice finds its place. Highly versatile, these headphones can be adapted to a wide range of musical genres, for a pleasant listening experience in any situation.
Mise en situation du Meze Audio 105 AER
Meze Audio 105 AER: Top-of-the-range design
The Meze Audio 105 AER headphones feature a “W”-shaped dome made of carbon-fiber-reinforced cellulose. It's thanks to this dome in particular that it's able to reproduce high frequencies with such a high level of detail and finesse. What's more, this material greatly helps to reduce unwanted resonances, thus contributing to a significant reduction in distortion.
The membrane surrounding the dome is made of PEEK (Polyether Ether Ketone), a material with excellent mechanical properties. PEEK is very rigid, but also very light and has good tensile strength, enabling every note to be brought to life in the finest detail. A copper-zinc alloy stabilizer completes the design, absorbing vibrations and eliminating the last traces of distortion.
Photo du transducteur du Meze Audio 105 AER
Meze Audio 105 AER: Comfortable ergonomics
The ergonomic headband perfectly distributes the weight of the headphones on the user's head for optimum comfort, enabling long listening sessions to be enjoyed without discomfort. The velvet earpads provide optimum passive isolation and a soft, breathable feel.
Zoom sur le Meze Audio 105 AER
Meze Audio 105 AER: durable materials
The headband of the 105 AER headphones is made of cellulose composite and carbon fiber, for maximum lightness and strength. The shells are made of ABS, offering enhanced shock resistance, while the transducer grilles combine solidity and aesthetics thanks to their special shape.
Photo de la coque du Meze Audio 105 AER
Photo du package du Meze Audio 105 AER
Meze Audio 105 AER: A detachable cable
The Meze Audio 105 AER features a detachable cable for replacement or upgrading, for extended headphone life or simply for upgrading. The cable supplied has 3.5mm TS connectors on the headphones side and a 3.5mm TRS termination. This ensures a high level of compatibility with most audio sources. Meze also supplies a 6.35mm jack adapter if required.
Product typeHeadphone
Headphone typeOpen-Back
FormatCircumaural
Transducer typeDynamic
Transducer diameterØ50mm
Frequency response5Hz-30kHz
Sensitivity112dB SPL (1kHz, 1mW)
Impedance42 ohm
MaterialABS shells
Zinc and steel structure
Leather headband
Velvet pads
Detachable cable
Headphone connectorsJack 3.5mm TS
TerminaisonJack 3.5mm TRS
Cable length1.8m
Cable with built-in microphone
Gross weight1.2kg
Package1x Meze Audio 105 AER headphones
1x Detachable Jack 3.5mm cable
1x Jack 6.35mm adapter
1x Storage pouch
Impedance (Ω)42
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)5
Highest frequency (Hz)30000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
MEZE AUDIO 105 AER Open-Back Dynamic Circumaural Headphones 112dB 42 Ohm 5Hz-30kHz
Meze Audio 105 AER headphones are dynamic circumaural open-air headphones featuring a high-performance, long-lasting audiophile design. In fact,...
