By buying this product you get 23 loyalty points
Dynamic Open-Back Headphone Ø50mm 64Ω 110dB 10Hz-80kHz
Moondrop unveils Void, an open-back dynamic headphone that is as powerful as it is comfortable. Its careful design, using a speaker specially developed by the brand, allows the headphones to provide a musical, dynamic and accurate sound, for an optimal listening experience both at home and on the move.
The Void is equipped with 50mm diameter dynamic drivers, specifically developed by the brand, allowing the headphones to provide excellent sound performance. The rest of the components are then perfectly tuned and optimized around this driver. The magnetic circuit has been designed to provide high efficiency to allow the Void to reproduce your music with dynamism and precision. The diaphragm is accompanied by a soft suspension and a metalized dome, ensuring a nice extension in the high frequencies and a nice dynamic in the midrange and bass.
| 1 | Metal coated dome |
| 2 | CCAW Voice coil |
| 3 | High efficiency magnetic circuit |
| 4 | Flexible damping suspension ring |
| 5 | N52 Magnet |
| Specifications | |
| Product type | Headphone |
| Headphone type | Dynamique Ouvert |
| Driver diameter | Ø50mm |
| Headphone connectors | Jack 3.5mm |
| Frequency response | 10Hz - 80kHz |
| Effective frequency response | 20Hz - 20kHz (IEC60318-4, -3dB) |
| Impedance | 64Ω ±15% @ 1kHz |
| Sensitivity | 110dB/Vrms @ 1kHz |
| General | |
| Color | White |
| Package | 1* Moondrop Void 1* Jack 3.5mm to Jack 6.35mm adapter 1* Jack 3.5mm cable |
| Color | White |
| Impedance (Ω) | 64 |
| Efficiency / Sensitivity (dB) | 110 |
| Lowest frequency (Hz) | 10 |
| Highest frequency (Hz) | 80 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Cable termination | Jack 6.35mm |
| Headphone / Earphone connector | Jack 3.5mm |
