MOONDROP X SINGER EDGE Wireless Headphones Black
With the Edge, Moondrop offers us a wireless, LDAC-compatible Bluetooth headphone featuring a low-distortion 40mm driver with a titanium-plated composite cone for highly defined, naturally textured sound. These headphones benefit from all Moondrop's expertise in noise suppression, including hybrid ANC and beamforming reduction during phone calls.
4.0 / 5
Reference : 20075
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 24-06-2026.
Moondrop X Singer Edge Dynamic Wireless Headphones Ø40mm Bluetooth 5.4 LDAC 20Hz - 20kHz Black
Moondrop Singer : Front view
Moondrop Singer : Summary of key features
Moondrop X Singer Edge: 40mm dynamic driver
The Edge is based on a 40mm dynamic driver. This driver incorporates a composite diaphragm with flexible suspension and a titanium-plated dome, ensuring excellent definition and a natural low-midrange texture. This diaphragm is accompanied by a CCAW voice coil and N52 magnetic circuit, guaranteeing low distortion and excellent dynamic range. Furthermore, this driver benefits from a custom acoustic cavity specially designed to get the best out of it, while isolating this part from the electronic circuits to avoid any interference.
Moondrop Singer : Composition Driver
Moondrop Singer : Noise reduction
Moondrop X Singer Edge: ANC / ENC / Transparency mode :
The Edge's active noise suppression is based on a hybrid FF + FB (Feedforward + Feedback) technology, using both the surrounding noise and an analysis of the signal produced to elaborate a phase signal opposite to the noise detected. Furthermore, a transparency mode is also available, so you can listen to your favorite tracks while being aware of your surroundings.
Furthermore, to provide effective noise reduction during telephone calls, the Edge is equipped with four microphones for beamforming noise reduction. This technique relies on several microphones picking up the same sound source. However, due to their different placements, the interference picked up by each of these microphones will be different, enabling them to be discriminated and suppressed.
Moondrop X Singer Edge: Excellent Bluetooth connectivity
To ensure stable signal transmission in any situation, the Edge includes the largest possible Bluetooth antenna, enabling it to maintain a perfect connection even in the most complex electromagnetic environments. Furthermore, the Singer is compatible with the Bluetooth LDAC codec, enabling high-resolution, broadband transmission of your favorite song.
Moondrop Singer : Bluetooth antenna
Moondrop Singer : Autonomy
Moondrop X Singer Edge: Autonomy and fast charging
To follow you wherever you go, Edge is equipped with a 48-hour battery. This is coupled with a fast-charging system that recharges the equivalent of 4 hours of listening in just 5 minutes.
Moondrop X Singer Edge: Ergonomics and wearing comfort
Particular attention has been paid to ergonomics and wearing comfort in the design of the Edge. The ear cushions are made of memory foam and shaped to fit the shape of the skull. Moreover, for greater practicality in transport, this helmet is equipped with a folding aluminum temple, both aesthetically pleasing and durable.
Moondrop Singer : Macro view of an ear pads
Moondrop X Singer Edge: VDSF model
Edge's headphones have been designed to offer a frequency response as close as possible to that of the VDSF model. Furthermore, thanks to the MOONDROP Link application available for Android and iOS, you can choose from several frequency response models, leaving more or less room for low frequencies.
Moondrop Singer : Frequency response
Product typeWireless headphones
Bluetooth version5.4
Bluetooth transmission protocolADP / AVRCP / HFP / HSP
Supported Bluetooth codecsSBC / AAC / LDAC
Charging portUSB-C
Operating distance15m (barrier-free open environment)
Driver40mm dynamic driver
Recharge time1.5h
Autonomy48h
Package1x Moondrop X Singer Edge
1x USB-A to USB-C cable
1x Carrying bag
Impedance (Ω)NC
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationUSB-A
Headphone / Earphone connectorUSB
2 reviews
Plutôt plaisant, nécessite parfois des DSP
Ce casque propose une isolation passive correcte. Les pads sont agréable. Moelleux et plutôt fluffy.
L'isolation active a été testé en environnement difficile avec notamment beaucoup de vent et l'exercice est plutôt réussi. Je n'ai cependant pas utiliser mon tourmalet PE200 à haute vitesse pour des sensation fortes sans...désagréments.
Ce casque est utilisé dans mon utilisation sans l'application, sous ArchLinux et mon Pixel, donc l'appareil devient autonome et toute les fonctionnalité hormis les presets intégrés sont accessibles.
[Volume Hardware/Amplification bluetooth] dissocié du mixeur: pipewire ou le mixeur android. Ce dernier étant à manipuler dans les paramètres développeurs pour opter pour les 3 codecs disponibles : SBC, AAC, LDAC. Un codec vient s'ajouter évidemment sous Linux avec le SBC-XQ.
J'utilise personnellement plus facilement easyeffect sous linux mais aurait tendance à opter pour une session Ardour avec une liste de plugins dédié plus complet pour mes sessions d'écoutes.
Sous android, j'utilise la suite poweramp.
Concernant les caractéristique sans post traitement ou brut :
La réponse globale s'appuie sur des basses profondes et étendues qui surprend au départ mais conçu pour une 'rétention' de l'utilisateur.
Le bas du spectre domine et les basses sont pas tout à fait les mêmes qu'un ATH-M50x, avec une définition et une texture curieuse qui demande un peu de temps avant de pouvoir en épouser les courbes.
Le dynamisme globale a tendance à pousser le médium, le son est chaud et on se retrouve assez rapidement dans une certaine intimité mais ça manque de punch, pour certains enregistrements.
Il existe cependant une manque de continuité de relief dans le haut du spectre, on peine à évaluer le spectre du 15-18khz de mon ressenti, ceci pourrait demander un plugin pour exciter cette bande.
Dans l'ensemble, ça reste très brouillon et l'émotion n'est pas toujours la.
This review has been posted for MOONDROP X SINGER EDGE Dynamic Wireless Headphones Ø40mm Bluetooth 5.4 LDAC 20Hz-20kHz Black
correct
Ce casque est orienté ambiophonique plus que hi-fi ; le confort et la douceur d'écoute sont privilégiés mais les détails sont audibles . Tout est fait pour ne pas agresser l'oreille . le volume maximum est limité mais ce n'est pas frustrant . Idéal pour la télévision et les films . En musique connectée en LDAC à mon smartphone la scène sonore est agréable . Un peu cher par rapport aux concurrents dans la même gamme de prix . Il existe plusieurs mode d'écoute sur l'application dédiée mais le mode standard m'a le plus convaincu .Le passage en LDAC s’effectue sur l'application . La scène sonore est le point fort au détriment de la dynamique un peu en retrait . Reste un bon produit mais il manque un petit quelque chose pour atteindre cinq étoiles . Content toutefois de cet achat . A noter un packaging qualitatif .
With the Edge, Moondrop offers us a wireless, LDAC-compatible Bluetooth headphone featuring a low-distortion 40mm driver with a titanium-plated...
