ROSESELSA DISTANT MOUNTAIN Headphone Black
Roseselsa's Distant Mountain are retro-looking headphones featuring a dynamic 40mm driver for rich, full-bodied reproduction with good treble extension. Moreover, the headphones are pleasant to wear thanks to their solid, skin-friendly materials and adjustment options.
Reference : 20734
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 01-07-2025.
Roseselsa Distant Mountain Dynamic Open-Back Headphone Ø40mm 32 Ohm 115dB 20Hz-20kHz Black
Roseselsa Distant Mountain : Front view
Roseselsa Distant Mountain : A transparent headphone
Distant Mountain is designed to keep you aware of your surroundings while remaining comfortable to wear. All you have to do is stop your music to hear your surroundings clearly, making these headphones ideal for outdoor use in city environments where awareness of your surroundings is a matter of safety.
Roseselsa Distant Mountain : Woman wearing the headphones in town
Roseselsa Distant Mountain : macro view of an earpiece
Roseselsa Distant Mountain : Meticulous aesthetics
The Distant Mountain has a delightfully retro aesthetic while using quality materials for maximum comfort and durability. The headband is made from stainless steel and covered in lambskin, ensuring a stable fit and a soft, skin-friendly feel. The ear cups are CNC-machined to give a classy, textured finish.
Roseselsa Distant Mountain : Dynamic driver
For its sound reproduction, the Distant Mountain relies on a dynamic driver with a 40mm-diameter diaphragm coupled to a neodymium magnet circuit. The result is a rich sound with natural highs and rich detail.
Roseselsa Distant Mountain : Driver
Roseselsa Distant Mountain : Ventilation system
Roseselsa Distant Mountain : Pressure control
The Distant Mountain incorporates a ventilation system that is several times superior to that of larger headphones. This system provides better control of internal pressure, resulting in greatly improved high-frequency extension.
Roseselsa Distant Mountain : Fine adjustment system
For the most precise fit possible, the Distant Mountain headband features adjustable earcups coupled to a graduated axis, so you can adjust your headphones symmetrically.
Roseselsa Distant Mountain : Macro view of the graduated axis
Product typeHeadphones
Headphones typeOpen-back
DriverØ40mm dynamic driver
Frequency response20Hz-20kHz
Sensitivity115dB
Impedance32Ω
Total harmonic distortion (THD)<2% @1kHz
Headphone connectorsMMCX
Cable terminationjack 3.5mm
Cable length1.2m
Microphone cable
Package1x Roseselsa Distant Mountain
1x 3.5mm Jack to MMCX cable 1.2m
1x Pair of spare foam pads
Impedance (Ω)32
Efficiency / Sensitivity (dB)115.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorMMCX
ROSESELSA DISTANT MOUTAIN Dynamic Open-Back Headphone Ø40mm 32 Ohm 115dB 20Hz-20kHz Black
Roseselsa's Distant Mountain are retro-looking headphones featuring a dynamic 40mm driver for rich, full-bodied reproduction with good treble...
