SIMGOT EP5 Headphone
The SIMGOT EP5 is a closed-back dynamic headphone designed for HiFi listening, monitoring, and gaming alike.
Reference : 22205
97,90 €tax incl.
81,58 € tax excl.
Shipping date: 17-11-2026.
Simgot EP5 Closed-Back Dynamic Headphones 50mm 32 Ohm 113dB 20Hz–20kHz
SIMGOT EP5
The Simgot EP5 is a closed-back dynamic headphone designed for HiFi listening, monitoring, and gaming alike. It is built around a 50mm full-range dynamic driver featuring a composite aluminum foil and flexible polymer diaphragm, a lightweight CCAW (Copper-Clad Aluminum Wire) voice coil, and a powerful N52 magnetic circuit, ensuring accurate sound reproduction, excellent dynamics, and deep bass. Its closed-back acoustic architecture combined with a multi-vent rear structure delivers a spacious soundstage while effectively minimizing sound leakage. With a 32Ω impedance, a sensitivity of 113dB RMS at 1kHz, and a frequency response ranging from 20Hz to 20kHz, the EP5 is easy to drive from a computer, digital audio player, or DAC/headphone amplifier. Its adjustable stainless steel and ABS headband, along with its synthetic leather earpads, provide outstanding comfort during extended listening sessions. It uses a detachable dual TRS connector cable made from high-purity OFC copper and is compatible with an optional balanced 4.4mm cable.
SIMGOT EP5
Simgot EP5: High-Performance 50mm Dynamic Driver
The Simgot EP5 features a 50mm full-range dynamic driver using a composite aluminum/polymer diaphragm, a CCAW voice coil, and a high-flux N52 magnet. Optimized through finite element simulation, this design reduces distortion, improves transient response, and delivers balanced sound with deep bass, natural mids, and detailed highs. Its acoustic tuning follows the H-2018 (Over-Ear) target curve, providing a neutral and accurate sound signature suitable for both professional monitoring and audiophile listening.
SIMGOT EP5: High-Performance 50mm Dynamic Driver
SIMGOT EP5: Closed-Back Acoustic Design and Superior Comfort
Simgot EP5: Closed-Back Acoustic Design and Superior Comfort
Thanks to its closed acoustic chamber and multi-vent rear plate, the EP5 combines excellent isolation with a surprisingly wide and natural soundstage. This architecture improves sound wave diffusion while reducing sound leakage, delivering an immersive listening experience even in shared environments. Its continuously adjustable stainless steel and ABS headband, combined with thick synthetic leather earpads, ensures excellent comfort and ergonomics during long listening sessions.
Simgot EP5: HiFi and Gaming Ready
The Simgot EP5 is designed to adapt to a wide range of applications. Its detachable dual TRS cable made from high-purity OFC copper ensures reliable signal transmission and can be replaced with an optional 4.4mm balanced cable for compatible audio sources. For gaming, it can be paired with the GEW1 USB sound card, which provides virtual 7.1 surround processing, multiple gaming audio profiles, volume adjustment, mute functionality, and microphone gain control. The external GH22 microphone completes the package by delivering high-definition voice capture for in-game communication and streaming.
SIMGOT EP5: HiFi and Gaming Ready
Technical Specifications
Product TypeHeadphones
Headphone TypeClosed-Back Over-Ear
DriverØ50mm Ultra-Magnetic Full-Range Dynamic Driver
DiaphragmMultilayer composite: Aluminum foil + PEK + PU
Frequency Response15Hz–50kHz
Effective Frequency Response20Hz–20kHz
Impedance32Ω
Sensitivity113dB/Vrms (@1kHz)
Detachable Cable
Cable ConductorsOFC Copper
Cable Length1.5m
Headphone Connector3.5mm TRS Jack
Cable Termination3.5mm Jack
Weight300g
Package Contents1x Simgot EP5
1x Detachable 3.5mm jack to 3.5mm jack cable
Impedance (Ω)32
Efficiency / Sensitivity (dB)113
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
Très interessant!
Voilà un casque fermé qui dans sa catégorie de prix a beaucoup de choses à donner. J'ai renoncé il y a peu à un casque du même type, un peu plus cher, très sérieux mais trop coloré en bas et en haut du spectre, Ici on est plus neutre, et même proche de la courbe Harman, pour peu de frai... Seules une légère brillance autour de 6khz et une légere éxagération à 100hz empêche d'atteindre la neutralité, mais une fois égalisé c'est vraiment très bon. D'autant que ce n'est pas non plus la conception légère (mais sérieuse) qui fatiguera les oreilles ou la tête, Il est très confortable.
A noter aussi une bonne spatialisation (surtout après EQ), je m'attendais à moins bien de ce côté.
This review has been posted for SIMGOT EP5 Closed-Back Dynamic Headphone Ø50mm 32 Ohm 113dB 20Hz–20kHz
