SPIRIT AUDIO TITANO HiFi Headphone Semi Closed Circumaural 2000mW 32 Ohm 18Hz - 39kHz
The Spirit Audio Titano semi-enclosed headphones were born after a long analysis of the world of headphone listening. Andrea Ricci, in this project, changes his design approach, moving from the pure research of a faithful sound reproduction, to an acoustically customized product capable of adapting to the user's needs.
By buying this product you get 190 loyalty points
Reference : 14767
1 900,00 €tax incl.
1 583,33 € tax excl.
Spirit Audio Titano
Casque HiFi Semi Fermé Circumaural 2000mW 32Ω 18Hz - 39kHz
Spirit Audio Titano Casque HiFi Semi Fermé Circumaural 2000mW 32Ω 18Hz - 39kHz
The Titano can be used for audiophile listening as well as by professionals in the studio. Considerable thought was also given to the use of the headphones themselves, allowing the semi-enclosed design to be defined, allowing the acoustic benefits of an open system to be enjoyed while allowing 50% less sound to escape outside the headphones. This adjustment allows a realistic listening volume to be maintained without disturbing people in the vicinity, while limiting background noise, allowing full appreciation of all sound details.
The Titano at the service of dedicated amplification
Another key point of this project is that - unlike the brand's high-end Twin Pulse headphones designed for stand-alone use - the Titano is designed to accompany and enable an amplification system to express its full potential.
The Titano's VPS system, in addition to varying the low-frequency response, also modifies the compression levels inside the acoustic chambers, thus better adapting to the characteristics of different types of amplification.
What's more, the Titano's combination of sensitivity and impedance allows even low-power systems to deliver more than convincing music reproduction.
A three-dimensional sound stage
The special combination of the headphone body structure and its VPS-equipped ear cushions is designed to generate a sound scene projected from the front while creating a sweeping sweep of the sound layers. This makes it possible to perceive a noticeable difference between sounds coming from close up, such as a solo instrument, and sounds coming from far away, such as the applause of an audience, without losing the perception of every detail.
High-sensitivity headphone
The Titano is designed to maximize response to different types of cables to vary the sonic character and adapt to different types of listening situations.
That's why this headphone can be used with a wide range of cables, from a single-core copper cable, offering warm and musical reproduction, to double-section cables with copper/silver cores that make the sound reproduction extremely detailed and dynamic.
It is also possible to take advantage of the benefits of Pure Silver cabling to achieve other nuances of sound without losing body and control of the bass range.
Optimal comfort for long listening sessions
The Titano's sophisticated design allows you to listen to your music in comfort, even in difficult environments. Materials such as Alcantara (R) and the special care given to the ear cushions allow the VPS system to ventilate the ear chamber while maintaining an optimal level of heat and humidity.
Product typeHeadphone
Headphone typeSemi closed circumaural
TechnologyMono Drive Spirit System
Cables length (removable)1.2m
2.2m
Power handling2000mW
Impedance32Ω
Frequency response18Hz - 39kHz
Calibrated on isophonic curves
Temperature range0°C - 50°C
Ear padsLeather / Alcantara
Earpads venting system
Weight440g
Impedance (Ω)32
Lowest frequency (Hz)18
Highest frequency (Hz)39000
The Spirit Audio Titano semi-enclosed headphones were born after a long analysis of the world of headphone listening. Andrea Ricci, in this...
