TONEWINNER AT-2300PRO AV Processor Home-Theater Amplifier Dolby Atmos DTS:X 7 Channels
New
The Tonewinner AT-2300PRO is a audio-video processor home theater amplifier high-end device featuring powerful multichannel amplification and a complete audio-video processing section dedicated to immersive installations.
By buying this product you get 149 loyalty points
Reference : 21701
1 490,00 €tax incl.
1 241,67 € tax excl.
Tonewinner AT-2300PROAudio-Video Processor Home Theater Amplifier Dolby Atmos DTS:X 7 Channels
Photo of the TONEWINNER AT-2300PRO
The Tonewinner AT-2300PRO is a audio-video processor and home theater amplifier high-end device featuring powerful multichannel amplification and a complete audio-video processing section dedicated to immersive installations. Designed around a 7-channel amplification architecture with an extensive preamplification section (configuration up to 5.3.2/11.3), it integrates amplification capable of delivering up to 230W under 8 ohms for the 3 front channels and 120W under 8Ω for the other channels, relying on a robust power supply and Hi-Fi circuitry ensuring stability and dynamics. Compatible with 3D audio formats Dolby Atmos, Dolby TrueHD, DTS:X and DTS-HD, it also supports modern video standards such as 4K, HDR10, Dolby Vision, HLG and 3D, with full HDMI signal management (HDMI 2.1, ARC, CEC, HDCP2.2).
Designed as a true audiovisual hub, the AT-2300PRO offers numerous features: audio playback via USB, TF card, Bluetooth, mobile app control, automatic calibration with room equalization, as well as advanced DSP for audio processing. Its comprehensive connectivity includes 6 HDMI inputs and 2 HDMI outputs, optical, coaxial and analog inputs, as well as dual subwoofer outputs. It integrates seamlessly into both home theater systems and advanced Hi-Fi or multimedia setups.
Key features of the TONEWINNER AT-2300PRO
Tonewinner AT-2300PRO : powerful and immersive 7-channel amplification
The Tonewinner AT-2300PRO relies on internal amplification capable of directly powering a complete immersive setup. With 7 amplified channels and a power output of 230W RMS under 8 ohms for the 3 front channels (LCR) and 120W RMS under 8 ohms for the other channels , it provides substantial power reserves to drive demanding speakers, even in large rooms.
This power is complemented by a refined design with controlled distortion (≤0.05%) and a high signal-to-noise ratio (≈98 dB), ensuring clear, dynamic and controlled sound reproduction, both for cinema and music listening.
TONEWINNER AT-2300PRO : powerful and immersive 11-channel amplification
Tonewinner AT-2300PRO : Dolby Atmos & DTS:X compatibility for realistic 3D sound
The AT-2300PRO supports the most advanced immersive audio formats, including Dolby Atmos and DTS:X, enabling a fully enveloping three-dimensional soundstage. It can handle complete configurations up to 7.3, with precise spatial positioning of effects.
It also remains compatible with previous formats (Dolby TrueHD, DTS-HD, etc.), ensuring full compatibility with current content, whether from Blu-ray, streaming or local files.
TONEWINNER AT-2300PRO : Dolby Atmos & DTS:X compatibility for realistic 3D sound
TONEWINNER AT-2300PRO : modern video section compatible with 4K HDR
Tonewinner AT-2300PRO : a modern video section compatible with 4K HDR
A true central hub of a home theater system, the AT-2300PRO ensures full management of high-definition video streams. It supports 4K, HDR10, Dolby Vision, HLG and 3D formats, with high bandwidth enabling 4K/60Hz RGB 4:4:4 signal passthrough.
Thanks to its HDMI 2.1 inputs/outputs, it allows easy connection of all modern sources (Blu-ray player, console, TV box), while ensuring optimal transmission to a TV or projector.
Tonewinner AT-2300PRO : advanced DSP and automatic calibration
The Tonewinner AT-2300PRO features full digital signal processing with DSP, allowing optimization of sound reproduction according to the listening environment. It offers:
  • Automatic calibration with acoustic correction
  • Adjustment of distances, levels and delays
  • Advanced room equalization
These features ensure coherent and balanced sound reproduction, even in complex rooms.
TONEWINNER AT-2300PRO : advanced DSP and automatic calibration
Tonewinner AT-2300PRO : Tonewinner mobile app & music streaming
The Tonewinner AT-2300PRO relies on a dedicated mobile application allowing easy control of the device and access to its multimedia features. This app enables remote control of audio settings, sources, volume and certain advanced parameters, with an interface adapted depending on the type of device connected via Bluetooth.
On the streaming side, the AT-2300PRO offers great flexibility. Thanks to its built-in Bluetooth receiver, it allows wireless music streaming from a smartphone, tablet or computer, with a stable and fast connection. It also supports direct playback of audio files stored on USB drives or micro SD cards, including high-resolution formats.
The Tonewinner app also provides easy access to popular music streaming services such as Spotify, Apple Music or Pandora, acting as a control interface to launch and manage playback from a mobile device.
TONEWINNER AT-2300PRO : Tonewinner mobile app & music streaming
Overview of the Tonewinner AT-2300PRO
Overview of the TONEWINNER AT-2300PRO
16x RCA line outputs
23x RCA line inputs
33x RCA karaoke line inputs
4Auto setup mic
52x coaxial inputs
62x microphone inputs
7Micro TF card slot
8Bluetooth antenna
9IR in
10Trigger out
11Micro USB port
12RS232 port
132x optical Toslink inputs
142x HDMI outputs
156x HDMI inputs
167x speaker binding post outputs
17IEC power input
Technical specifications
Product typeAudio-Video Processor Home Theater Amplifier
DAC2x  CS42528
ProcessorADSP 21573
Inputs6x RCA stereo
2x Coaxial
2x Optical Toslink
6x HDMI 2.1
TF Card slot
USB-A (Host)
Bluetooth
Outputs6x RCA line
2x HDMI 2.1 (including one eARC compatible)
7x speaker terminals
Other connectivity1x IR input
1x RS232 port
Supported audio formatsDolby Atmos
Dolby True HD
DTS:X
DTS Virtual:X
Supported video formats4K UHD 60Hz
3D
Dolby Vision
HDR10
HLG
Decoding7.3.4
Power230W RMS under 8 ohms for the 3 front channels (LCR)
120W RMS under 8 ohms for the 4 other channels
Nominal impedance8 ohms
SNR95dB
Distortion< 0.05%
Gain38dB
Frequency response10Hz-20kHz
EqualizerCustomizable for each input
Control application
Power supply110-115V (60Hz) / ~220-230V (50Hz)
Dimensions431 x 368 x 106mm
Weight16.3kg
Package contents1x Tonewinner AT-2300PRO
1x 4K HDMI cable
1x Remote control
1x Power cable
InputMicro SD
InputHDMI
OutputHDMI
OutputSpeaker terminal
Channel11.3
Channel7
Channel5.3.2
ClassClass A / AB
Amplifier chipTransistors
Power (W)230.0
Remote ControlControl app
Remote ControlYes
The Tonewinner AT-2300PRO is a audio-video processor home theater amplifier high-end device...
