This Audiophonics RJ45 Cat 8.1 STP Ethernet cable, hand-assembled in our workshops in France, incorporates top-quality components to deliver excellent transmission performance. It uses Sommercable Mercator Cat 8.1 cable, with 8 OFC copper conductors of 0.32mm² each. The conductors are twisted and double-shielded with tinned copper braid. The cable is terminated on both sides with Telegartner MFP8 Cat 8.1 T568B RJ45 connectors with gold-plated contacts and zinc-molded shielding. Finally, the cable is covered with a red, black and gray braided sheath from Viablue.
Thanks to its meticulous design, this Audiophonics RJ45 Ethernet cable reaches Cat 8.1, enabling very high transmission speeds of up to 40Gbps.
| Specifications | |
| Product type | Ethernet RJ45 cable |
| Length | 3m |
| Category | Cat 8.1 |
| Bandwidth | Up to 40Gbit/s |
| Transmission frequency | 20000MHz |
| Technologies | PoE / PoE + / VoIP |
| Cable impedance | 110Ω |
| Cable conductors material | OFC copper |
| Cable conductors section | 8x0.32mm² (22AWG) |
| Connectors contacts plating | Gold |
| Connectors body material | Cast zinc |
| Specifications | |
| Color | Black, red and gray |
| Length (m) | 3.0 |
| Shielding | Yes |
| Section (mm²) | 0.32 |
| Connector | RJ45 |
| Conductors Plating (Cable) | None |
