Section (mm²)
0 mm - 6 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Roland S.
Dac tv
Walter V.
Great product!
Joli mais non..
Balanced Cables
Balanced Cables
