NEOTECH NECE-3200 III Cable for Headphone
The Neotech NECE-3200 III is an IEM cable featuring a 4-conductor Litz multi-strand design in silver-plated UP-OCC copper. This design greatly optimizes signal transmission, while the Litz wire structure insulates each strand with a polyvinyl chloride coating.
Reference : 20544
79,05 €tax incl.
65,87 € tax excl.
Shipping date: 01-12-2026.
Câble vendu au mètre
Neotech NECE-3200 III Cable for Headphone Litz Silver Plated UP-OCC Copper Ø3mm
NEOTECH NECE-3200 III picture
The Neotech NECE-3200 III is an IEM cable featuring a 4-conductor Litz multi-strand design in silver-plated UP-OCC copper. This design greatly optimizes signal transmission, while the Litz wire structure insulates each strand with a polyvinyl chloride coating. This reduces the impact of the skin effect, i.e. a current that flows only on the surface of the conductor at high frequencies, as well as the proximity effect, which increases resistivity. The braids help reduce EMI/RFI interference for a wide soundstage and spatial rendering.
To achieve a good solder joint on this type of cable, it's best to remove the coating on the soldering zone using a soldering flux.
Product typeHeadphones / IEM cable
StructureLitz wire
Conductors4
Conductors materialUP-OCC silver-plated copper
InsulationPVC
Section25AWG (0.162mm²)
ColorWhite
PackageSold by meter
Diameter (mm)3.0
Number of conductors4
Insulation materialPVC
ShieldingNo
Section (mm²)0.16
Ground / ShieldingNo
NEOTECH NECE-3200 III Cable for Headphone Litz Silver Plated UP-OCC Copper Ø3mm
The Neotech NECE-3200 III is an IEM cable featuring a 4-conductor Litz multi-strand design in silver-plated UP-OCC copper. This design greatly...
