The Neotech NEI-1002 II interconnect cable retains the high-quality design of its predecessor, with effective shielding and two UP-OCC silver conductors, but this time plated with a mix of UP-OCC silver and gold. The conductive materials ensure optimal signal transmission, while the shielding, consisting of silver-plated OFC copper mesh and AL-Mylar aluminum foil, protects the signal from EMI/RFI interference. The assembly is completed with PTFE insulation. The NEI-1002 II is a balanced cable that can be used with both RCA and XLR connectors, depending on how it is assembled.
Ideal for RCA modulation cables, it can also be used as an XLR cable when the shielding is used as RETURN. With its high-quality construction, the Neotech NEI-1002 II will fit perfectly into a high-end sound system.
Product type | Interconnect cable |
COnductors material | UP-OCC silver |
Conductors plating | Mixed UP-OCC silver and Gold |
Cross-section | 2x AWG22 (0.32mm²) |
Shielding | Silver-plated copper braid Al-Mylar foil |
Insulation | PTFE |
External diameter | Ø13mm |
Package | Sold by meter |
Diameter (mm) | 13.0 |
Number of conductors | 2 |
Number of conductors | 3 |
Insulation material | PTFE |
Shielding | Yes |
Section (mm²) | 0.32 |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | Gold |
Conductors Plating (Cable) | Silver |
Ground / Shielding | Yes |
