NEOTECH NEI-1002 II Interconnect Cable
New
The Neotech NEI-1002 II cable retains the high-quality design of its predecessor, with effective shielding and two UP-OCC silver conductors, but this time plated with a mixture of UP-OCC silver and gold.
Reference : 21090
179,00 €tax incl.
149,17 € tax excl.
Câble vendu au mètre
Neotech NEI-1002 II Interconnect Cable UP-OCC Silver UP-OCC Silver/Gold Plating Shielded 2x0.32mm² Ø13mm
NEOTECH NEI-1002 II picture
The Neotech NEI-1002 II interconnect cable retains the high-quality design of its predecessor, with effective shielding and two UP-OCC silver conductors, but this time plated with a mix of UP-OCC silver and gold. The conductive materials ensure optimal signal transmission, while the shielding, consisting of silver-plated OFC copper mesh and AL-Mylar aluminum foil, protects the signal from EMI/RFI interference. The assembly is completed with PTFE insulation. The NEI-1002 II is a balanced cable that can be used with both RCA and XLR connectors, depending on how it is assembled.
Ideal for RCA modulation cables, it can also be used as an XLR cable when the shielding is used as RETURN. With its high-quality construction, the Neotech NEI-1002 II will fit perfectly into a high-end sound system.
NEOTECH NEI-1002 II structure
Product typeInterconnect cable
COnductors materialUP-OCC silver
Conductors platingMixed UP-OCC silver and Gold
Cross-section2x AWG22 (0.32mm²)
ShieldingSilver-plated copper braid
Al-Mylar foil
InsulationPTFE
External diameterØ13mm
PackageSold by meter
Diameter (mm)13.0
Number of conductors3
Number of conductors2
Insulation materialPTFE
ShieldingYes
Section (mm²)0.32
Conductors material (Cable)Silver
Conductors Plating (Cable)Gold
Ground / ShieldingYes
NEOTECH NEI-1002 II Interconnect Cable UP-OCC Silver UP-OCC Silver/Gold Plating Shielded 2x0.32mm² Ø13mm
The Neotech NEI-1002 II cable retains the high-quality design of its predecessor, with effective shielding and two UP-OCC silver conductors, but...
