RAMM AUDIO GENESIS7 Balanced Interconnect Cable
New
The Ramm Audio GENESIS7 is a balanced interconnect cable designed for Hi-Fi and High-End systems where signal preservation and interference control are central concerns. Its CuGr technology combines high-purity monocrystalline OCC copper solid-core conductors with graphene; according to the manufacturer, this combination can increase electrical conductivity by up to 40% compared to traditional copper conductors.
Reference : 22580
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 20-11-2026.
Câble vendu au mètre
RAMM AUDIO GENESIS7 Balanced Interconnect Cable Graphene OCC Copper Ø9.3mm
Ramm Audio GENESIS7: Spool view
Ramm Audio GENESIS7: Signal architecture
The internal structure separates the signal into three fully isolated paths, to suit balanced applications and limit crosstalk between the conductors. Each core uses an AirInside geometry and polypropylene and Mylar insulation; this design aims to reduce parasitic capacitance and better control internal resonances, which helps preserve signal integrity, particularly over long distances.
Ramm Audio GENESIS7: Shielding and construction
A multilayer shield protects the conductors from electromagnetic and radio-frequency interference, while an internal cotton filling stabilizes the assembly and contributes to vibration control. The flexible PVC and Mylar outer jacket is complemented by a nylon braid reinforced at the ends, combining mechanical protection and flexibility to ease installation within an audio system.
Ramm Audio GENESIS7: Internal diagram
Technical specifications
Product typeInterconnect cable
Conductor materialsGraphene OCC copper
Shielding
Insulation
Cable diameterØ9.3mm
Inductivity1.4µH/m
Resistance0.03Ω/m
Capacitance184pF/m
Section3x 0.50mm²
ColorGreen and black
PackageSold per meter
Diameter (mm)9.3
Number of conductors3
Insulation materialPE
ShieldingYes
Section (mm²)0.50
Conductors material (Cable)Graphene
Ground / ShieldingYes
The Ramm Audio GENESIS7 is a balanced interconnect cable designed for Hi-Fi and High-End systems where signal preservation and interference control...
