TRIANGLE BP450 Banana Plugs (Set x4)
Triangle's BP450 banana plugs feature gold-plated contacts that provide excellent conductivity while effectively protecting them from corrosion. The body is made of anodized aluminum to ensure proper insulation. Compatible with most existing cables up to 4mm² in cross-section, it screws easily onto a stripped cable.
Reference : 21775
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 17-11-2026.
Triangle BP450 Banana Plugs Gold-Plated 3.6mm (Set of 4)
Photo of a box of BP450 banana plugs, sold in sets of 4
Product typeBanana plugs
Contact platingGold
Max. cable cross-section4mm²
Conductor diameter3.6mm
Conductor length35mm
Capsule Dimensions30x12.5x12.3mm
Finishing cap dimensions22.5x7.4x7.4mm
Net Weight78g
Package4x BP450 Banana Plugs
1x Ø1.5 mm Allen wrench
Max cable diameter (mm)3.6
Mounting typeTo screw
ConnecticMale
ConnectorBanana
TRIANGLE BP450 Banana Plugs Gold Plated Ø3.6mm (Set x4)
Triangle's BP450 banana plugs feature gold-plated contacts that provide excellent conductivity while effectively protecting them from...
