LG ELECTRONICS INR18650MJ1 18650 Accumulator Lithium-Ion Battery
The LG INR18650MJ1 Lithium-Ion battery is ideal for providing devices with equivalent voltage and current requirements with clean, stable and noise-free power.
Reference : 22490
5,95 €tax incl.
4,96 € tax excl.
Shipping date: 01-12-2026.
LG ELECTRONICS INR18650MJ1 18650 3.6V - 3.7V 3500mAh Rechargeable Lithium-Ion Battery
LG INR18650MJ1
The LG INR18650MJ1 Lithium-Ion battery is ideal for providing devices with equivalent voltage and current requirements with clean, stable and noise-free power. It can, for example, power certain small Class D amplifiers, such as some JAB amplifiers from Sure Electronics, or be integrated into the design of portable battery-powered speakers, as the battery is rechargeable.
It offers a typical capacity of 3500mAh (3400mAh minimum) for a nominal voltage of 3.6 to 3.7V. With its Flat Top design, it measures 18.30mm in diameter and 65.1mm in height, and weighs only 49g.
LG INR18650MJ1
Technical specifications
Product typeLithium-Ion battery
Battery type18650
ConnectorFlat Top
Typical capacity3500mAh
Minimum capacity3400mAh
Nominal voltage3.6V - 3.7V
Charging voltage4.2V ± 0.05V
Discharge voltage2.5V
Max. output current10A (continuous load)
Charging methodCC-CV
Normal charging current1700mA
Charging time at 1700mA3h
Fast charging current3400mA
Charging time at 3400mA1.5h
Constant discharge current680mA
Chemical compositionLiNiCoAlO2
Diameter18.30mm ± 0.05mm
Length65.1mm ± 0.05mm
Weight49g ± 0.01g
Packaging1x LG INR18650MJ1 Lithium-Ion battery
Rated voltage (V)3.7
Rated voltage (V)3.6
LG ELECTRONICS INR18650MJ1 18650 Accumulator Lithium-Ion Battery 3.6V - 3.7V 3500mAh Rechargeable
The LG INR18650MJ1 Lithium-Ion battery is ideal for providing devices with equivalent voltage and current requirements with clean, stable and...
