Rechargeable Battery IFR22650 LiFePO4 3.2-3.3V 2000mAh
This IFR22650 battery with a LiFePO4 (Lithium-Iron-Phosphate) chemical composition offers a nominal voltage of 3.2V-3.3V and a capacity of 2000mAh. Durable, it can be subjected to 1000 charging cycles.
Reference : 14227
8,90 €tax incl.
7,42 € tax excl.
Shipping date: 02-06-2026.
3 >Month warranty
Accumulateur IFR22650 LiFePO4 3.2-3.3V 2000mAh Rechargeable
This IFR22650 battery with a LiFePO4 (Lithium-Iron-Phosphate) chemical composition offers a nominal voltage of 3.2V-3.3V and a capacity of 2000mAh. Durable, it can be subjected to 1000 charging cycles. LiFePO4 batteries have the advantage over conventional Li-Ion batteries of being more durable (higher number of charging cycles), less sensitive to partial charges and withstanding higher currents. They are also more reliable and the voltage delivered during discharge is more stable. These batteries are also less polluting and can be stored for a longer period of time.
Batteries provide your devices with a clean, stable and noiseless power supply. For example, they can power some HiFi modules or be integrated into the design of portable mobile speakers.
Product typeRechargeable battery
Capacity2000mAh
Voltage rating3.2-3.3V
Discharge voltage2V
Max. continuous discharge3C 6A
Charging current0, xx - 2.00A
Charging voltage3.65V
Positive poleFlat
Chemical compositionLiFePO4
DiameterØ22.1 +/-0.25mm
Height65 +/-0.3mm
ConnectorFlat top
Weight63g
Charging methodCC-CV
Rated voltage (V)3.2
Rated voltage (V)3.3
This IFR22650 battery with a LiFePO4 (Lithium-Iron-Phosphate) chemical composition offers a nominal voltage of 3.2V-3.3V and a capacity of 2000mAh....
