Battery Power Supply Module 3.3V
The Ian Canada LifePo4 Mini 3.3V is a high performance yet affordable battery power supply. It uses one or two LifePo4 26650 batteries (sold separately) to provide a clean, stable power supply. As a completely passive power supply, it generates no feedback and has no active components. In pure output mode, only fully charged batteries are applied to the load. The module is also capable of delivering dynamic current up to 240A with an internal ESR of less than 3mΩ. (Continuous output mode, two batteries in parallel). This type of power supply is ideal for all sensitive audio devices, such as a low jitter clock, DAC or FIFO buffer.
Key features :
Product type | Battery power supply |
Batteries | 2x 26650 (sold separately) |
Input voltage | 4-5VAC 5-6VDC |
Output voltage | 3.3V |
Dynamic output voltage current | Up to 240A |
Output ESR | < 3mΩ |
Dimensions | 132 x 56mm |
Input | USB |
Input | Solder pad |
Output | PCB Connector |
Output | Screw terminals |
Output voltage (V) | 3.3 |
Output current (A) | 240.0 |
Input voltage (V) | 5.0 |
Power Supply | Battery |
