Fait parfaitement le job pour alimenter un préamplificateur phono. MAIS attention le set de câbles et leds n'est pas livré avec comme indiqué précédemment et il est quasi indispensable.
Battery Management System Module 5x Lithium 18650
The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery slots. The BCPB3 can thus accommodate 5 Lithium 18650 batteries in series and can be used as a power bank, as a power supply or simply to recharge your batteries for external use. The module supports a wide range of input charging voltages and hybrid charging sources. Any 5-24V 2A AC adapter can be used to charge the batteries with the BCPB3.
The balancing and protection circuitry constantly monitors each cell voltage, charge/discharge current and temperature to provide effective protection against overloads, overdischarges, input/output overcurrents, short circuits and overtemperatures.
Lithium 18605 batteries are sold separately.
Product type | BMS module (Battery Management System) |
Compatible battery type | Lithium 18650 |
Number of battery slots | 5 |
Power voltage | 5-24V 0.5-2A |
Power output | unregulated Full load: 21V Unloaded: 15V Possibility of output 2x5V 2A regulated with a USB output module |
Protection | Short circuits Over temperature Over voltage Under voltage Overcharge Overdischarge |
Solar charging support | |
Multiple discharging ports | |
Max discharge current | 5A |
Dimensions | 122 x 91.5 x 35mm |
Weight | 168g |
Input | PCB Connector |
Input | NC |
Output | PCB Connector |
Output voltage (V) | 21.0 |
Output current (A) | 5.0 |
Input voltage (V) | 24.0 |
Input voltage (V) | 5.0 |
Power Supply | Battery |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Gérard M.
jb b.
