NEOTECH NES-3003 MK2 Speaker Cable UP-OCC Copper Silver Plated 4x1.3mm² Ø19mm
The Neotech NES 3003 MKII loudspeaker cable has a special hybrid topology to reduce the effects of capacitance and inductance. Composed of OCC and silver-plated OCC copper, it offers qualities of timbre, dynamics and readability, usually contradictory.
Strengths:
  • Double structure OCC and OCC silver plated
  • Shielded speaker cable
  • Anti-static outer casing
Reference : 12502
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 23-04-2026.
Câble au mètre
NEOTECH NES 3003 MKII
Speaker Cable UP-OCC Copper Silver plated 8x1.3mm² Ø19mm
The Neotech NES-3003 MKII loudspeaker cable is the result of today's recognized mastery in the use of OCC (Ohno Continuous Cast) copper, the Asian brand being the leader in integrating this advanced technology of copper treatment by liquid nitrogen and controlled cooling temperatures offering a purity of 99.9% ( 9N ).
The internal configuration of this cable is based on a hybrid structure of two conductors (black and white) on a particular topology and two others on another topology (red and black) cancelling the inductive and capacitive effects.
The special feature of the NEOTECH NES 3003 MK3 is the braided and strapped shielding, an original solution not found in other loudspeaker cable manufacturers and rarely used, which significantly reduces the noise without increasing the capacitance effects. The PVC sheath finishing the cable is fully antistatic treated.
The qualities of this cable are based on a perfect balance between timbre, seating and definition, which usually oppose each other. This is certainly one of the best performing cables on the market for any amateur who wants to increase the resolution of his Hifi system without sacrificing its balance and neutrality with a readability of the bass reinforcing the quality of the sound scene between the speakers.
To bi-wire your speakers, connect the red wire to the "+" terminal of the high midrange and the blue wire to the "-" terminal of the high midrange. The white wire should be connected to the "+" terminal on the bass and the black wire to the "-" terminal on the low end of your speakers.
Do not forget to remove the straps from the terminal blocks of your speakers in case of bi-wiring or bi-amplification.
Neotech NES-3003 MKII Câble HP Cuivre Hybride Multibrins UP-OCC Plaqué Argent 8x1.3mm² Ø19mm
Product typeSpeaker cable (bi-wiring option)
Number of wires4 (each of Ø5mm)
Conductors materialOCC Silver plated OCC Copper
Section9AWG / 6mm²
Protection sheathInternal : Polypropylene
External : Anti-static PVC certified CL3 flame retardant
ShieldingMetal braid
ColorMetal gray
Diameter (mm)19.0
Length (m)Sold by length
Number of conductors4
Insulation materialPVC
Insulation materialPE
ShieldingYes
Section (mm²)6.00
Ground / ShieldingYes
8 reviews
Se sont d'excellent câbles qui non rien à envier à des marques dites "haut de gamme" et hors de prix.
This review has been posted for NEOTECH NES-3003 MK2 Speaker Cable UP-OCC Copper Silver Plated 4x1.3mm² Ø19mm
Shame to be discontinued
This is an astonishing cable. I was using the Nemos 3080 which is a great cable. The 3003 has taken a long time to break in but it is truly revelatory with no harshness from the silver at all.
Bi amplification
Difficile à monter,pas d’indications de montage,faut-il garder les fils argentés ou les supprimer comme le montre une vidéo you tube?dans l’expectative je l’ai les enroulées autour du cuivre.
Des précisions de montage de la part d’ audiophonics seraient bienvenus au prix de ce câble.
Ceci dit je ne regrette pas cet achat,le son est vraiment bon sur tous les critères.
Un avis de quelqu’un en ayant aussi l’expérience en France peut être ?
Difficult DIY but worth it
Not the easiest to terminate properly, but well worth the effort.
Very neutral speaker cable with good soundstage and placement of instrument and voices.
I’m using it single wire; red + white and black + blue.
The shield of the individual wires (silverplated copper) is twisted together with the copper.
Well worth the money
exceptional cables
exceptional cable, remarkable 3D image, the instruments appear more in focus and great musicality.
Excellent audiophonic in very fast shipping.
The Neotech NES 3003 MKII loudspeaker cable has a special hybrid topology to reduce the effects of capacitance and inductance. Composed of OCC and...
