The result of the latest generation of development by WBT, the 0708Cu speaker terminals feature pure copper conductors and a gold-plated plating. Thanks to the separation of the transmission line from the mechanical chassis, it is now possible to use high-quality materials for each component of these terminal blocks. Although the best electrical...
These WBT-0730.01 Binding post from the Topline series feature a high-end design. They feature 24K gold plating for optimum conductivity and resistance to corrosion and oxidation. In addition, the two-piece clamping system ensures high contact pressure.
WBT-0735 speaker terminals are 24k gold-plated and polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design.
WBT-0763 speaker terminal blocks are 24k gold-plated, multilayer polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design.
Xangsane's XS-6001AU LONG speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall thicknesses from 2mm to 18mm maximum. They feature non-slip seals. Connector contacts are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation.
Xangsane's XS-6001AU SHORT speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall thicknesses from 2mm to 4mm maximum. They feature non-slip seals. Connector contacts are made of gold-plated pure copper for enhanced conductivity and resistance to corrosion and oxidation.
Xangsane's XS-T072 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 7mm and a minimum of 3mm. Connectors are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation.
Xangsane's XS-T075 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 20mm and a minimum of 3mm. Connectors are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation.
