Connector
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Accepts Banana Plugs
Max panel thickness
mm
mm
David H.
Une révélation ! Le pilier de mon système haut de gamme
Configuration : Holo Audio RED (USB) DAC Audiomat Maestro 3 Ampli Aria EL34 NOS Carbon Cabasse Pacific SCS.
Avis détaillé :...
Gabriel G.
Naturel
J'ai les deux versions, argent et cuivre, de ce câble Neotech. Sur un DAC Audio-gd R1, je préfère utiliser le cuivre à...
David H.
Fait parfaitement le travail
Un peut dure de rentre le 4mm2
Binding Posts & Terminals
Discover our range of speaker terminals, alone or mounted on a plate, for the design of your speakers or HiFi amplifiers.
  • Binding Posts
    Binding Posts
    Discover our range of speaker terminals (without mounting plate) for the design of your speakers or amplifiers.
  • Speaker terminals
    Speaker terminals
    Discover our range of speaker terminals mounted on plates or mounting brackets, for the design of your HiFi speakers.
