FIIO FT13 Audio Headphones Purpleheart Wood
The FiiO FT13 is a high-performance closed-back dynamic headphone with an exceptional design and stunning Purpleheart wood ear cups. Its meticulous design, featuring large 60mm drivers, delivers rich, precise sound with a wide soundstage.
By buying this product you get 32 loyalty points
Reference : 21217
329,00 €tax incl.
274,17 € tax excl.
Shipping date: 17-11-2026.
FiiO FT13 Dynamic Closed-Back Headphones Ø60mm 32Ω 7Hz-40kHz Purpleheart Wood
FiiO FT13
FiiO FT13
FiiO FT13: Stunning Purpleheart wood shells
Following the success of the FT1 headphones, FiiO sought out a new type of wood in order to offer an improved version of the original model. The brand turned to Purpleheart wood, an exotic species native to South America. This wood is not only exceptionally sturdy, but also has a unique color. Over time, this wood, which is initially light brown, transforms into a beautiful purple.
This type of wood has been used for many instruments since the 1920s. Once it arrives at the headphone production site, the wood is stabilized, then aged in a dark room for several months to achieve its final color. It is then carefully selected, carved, polished, and lacquered.
FiiO FT13: Purpleheart wood shells
FiiO FT13: Large 60mm dynamic speaker
The FT13, like the FT1 before it, features a large 60mm diameter dynamic driver. This allows it to handle more power and deliver sound reproduction with less distortion, faster transients, and deeper, more powerful bass.
The FT13 speaker features a new composite diaphragm made from birch. This design allows for precise adjustment of the diaphragm's resistance and rigidity to achieve new sound goals. During the design process, wool fibers are added for flexibility, giving the diaphragm a natural sound and warm sound signature.
This diaphragm features a “W” design inspired by cone speakers. Compared to membranes commonly used in headphones, this design increases the effective vibration surface area by 25.8%. It consists of a rigid dome and a flexible suspension. The rigid dome covers a larger surface area than a conventional diaphragm, and because the coil drives it directly, less energy is lost during vibration transfer, increasing efficiency and reducing distortion.
Fiio FT13: 60mm dynamic speakers
FiiO FT13: Closed-back design
The FiiO FT13 features a closed-back design that provides excellent sound isolation, coupled with an integrated passive noise reduction system. This includes a wave dissipation chamber, a rear cavity with damping cotton, and a U-shaped acoustic tube. Together, these elements reduce ambient noise by up to 26dB. In addition, this closed-back design prevents sound leakage to the outside, making it ideal for quiet environments.
Fiio FT13: Closed-back design
FiiO FT13: U-shaped damping tube
The FT13 is equipped with a U-shaped damping tube that utilizes the airflow inside the headphones to optimize sound reproduction. The design of this tube has been carefully studied to reduce resonance frequencies and achieve deeper, more precise bass.
FiiO FT13: Large CCAW coil
The FT13 incorporates a large CCAW coil imported from Japan, composed of an extremely fine 0.035mm wire and a particularly lightweight KSV support. These components drastically reduce the moving mass of the diaphragm, resulting in a faster response and limiting unwanted reverberations. The coil has a diameter of 25mm, promoting high efficiency, rich mids, and fast transients.
FiiO FT13: Angled speaker design
The FT13 uses angled speakers, helping to deliver a beautiful soundstage. The conical deflector promotes precise placement of each instrument within this soundstage.
FiiO FT13: Angled speakers
FiiO FT13: Low impedance, high sensitivity
The impedance, sensitivity, and frequency response of the FT13 make it an ideal choice for audiophiles with high-end equipment, as well as listeners who want to enjoy a high-quality listening experience regardless of their source device.
FiiO FT13: low impedance, high sensitivity
FiiO FT13 : High-end cable
FiiO FT13: High-end cable
The cable supplied with the FT13 ensures excellent signal transmission quality thanks to its eight-strand braided design. These strands are made of Furukawa single-crystal copper conductors and silver-plated OFC copper, with each polarity having a 17AWG cross-section.
FiiO FT13: Suede and lambskin pads
Two pairs of earpads are included with the FT13, each offering excellent comfort and durability. The first pair features a breathable, sweat-resistant, and easy-to-clean lambskin leather cover. The second pair features a soft and flexible suede cover. Each earpads is made of memory foam, which molds perfectly to the shape of the ear.
FiiO FT13: Leather and memory foam pads
FiiO FT13
FiiO FT13: Adjustable magnesium alloy headband
The FT13 also features an adjustable magnesium alloy headband. This sturdy system allows for precise adjustment to fit any head perfectly. The part that comes into contact with the head is covered with durable, breathable lambskin leather. The headphones offer excellent comfort, even during long listening sessions.
FiiO FT13 : adjustable headband
FiiO FT13: Adjustable ear cups
The FT13 ear cups can be rotated on a three-axis system, contributing to the headset's ergonomics. This design promotes optimal comfort while preventing sound leakage.
FiiO FT13: Detachable connectors to fit all equipment
The FT13 comes with several detachable connectors to fit most source devices. These include a 3.5mm jack connector, a 4.4mm jack connector, a 3.5mm to 6.35mm jack adapter, and a 4.4mm to 4-pin XLR adapter.
FiiO FT13: Interchangeable connectors
FiiO FT13 : Pochette de rangement
FiiO FT13: Linen storage pouch
The linen protective pouch supplied with the FT13 is ideal for protecting the headset when traveling or for storing it when not in use.
Product typeHeadphones
Headphone typeClosed-back
Dynamic
Frequency response7Hz - 40kHz
Speakers diameterØ60mm
Dynamic impedance32Ω
Sensitivity98dB/mW @ 1kHz 113dB/Vrms @ 1kHz
Earcup pressure4.2N ±0.3N
Cable conductors materialFurukawa single-crystal copper + silver-plated OFC copper
Cable length1.5m
Headphone connectorsJack 3.5mm TS
Cable connectorsJack 3.5mm / 4.4mm
Earcup shells materialPurpleheart wood
Weight356g
ColorNatural purpleheart wood
Package1x FiiO FT13
1x Pair of suede earpads
1x Pair of lambskin pads (pre-installed)
1x Detachable 4.4m balanced jack connector
1x 4.4mm female jack to 4-pin XLR adapter
1x 3.5mm to 6.35mm jack adapter
1x Detachable single-ended 3.5mm jack connector
1x Storage pouch
1x Cleaning cloth
1x Storage case
ColorWood
ColorRed
Impedance (Ω)32
Efficiency / Sensitivity (dB)113
Lowest frequency (Hz)7
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationXLR 4-pin
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
FIIO FT13 Dynamic Closed-Back Headphones Ø60mm 32Ω 7Hz-40kHz Purpleheart Wood
The FiiO FT13 is a high-performance closed-back dynamic headphone with an exceptional design and stunning Purpleheart wood ear cups. Its meticulous...
