CLARK SYNTHESIS DILUVIO AQ339-100 Aquasonic Underwater Speaker
The Diluvio™ AQ339-100 underwater speaker from Clark Synthesis is the only underwater speaker in the world to offer full frequency and total fidelity. Private pool enthusiasts, amateur swimmers, and competitive swimmers agree that the Diluvio™ transforms any pool experience into something truly spectacular.
By buying this product you get 234 loyalty points
Reference : 21204
2 340,05 €tax incl.
1 950,04 € tax excl.
Clark Synthesis Diluvio AQ339-100 Aquasonic Underwater Speaker135W 4 ohm 20Hz-17kHz
Photo du Clark Synthesis Diluvio AQ339-100
The Diluvio™ AQ339-100 underwater speaker from Clark Synthesis is the only underwater speaker in the world to offer full frequency and total fidelity. Private pool enthusiasts, amateur swimmers, and competitive swimmers agree that the Diluvio™ transforms any pool experience into something truly spectacular. The Diluvio™ brings water to life, allowing music and sounds to be heard through the body beneath the surface of the water. It requires an amplifier to operate. Clark Synthesis recommends a stable 4-ohm amplifier capable of delivering 125-150 watts at 4 ohms (per speaker).
Dimensions du Clark Synthesis Diluvio AQ339-100
Product typeAquasonic underwater speaker
Nominal diameter20.32cm (8")
Power handlingRMS: 135W
Max: 400W
Impedance4 ohm
Tactile frequency response10-800Hz
Frequency response20Hz-17kHz
Transduction force2.8 lb-ft/watt
Tactile force peak378 lb-ft
Height5.08cm (2.25")
Cable30.48m of 16-2 cable approved for underwater use
Weight4.6kg (10.1LBS)
Package1x Clark Synthesis Diluvio AQ339-100 underwater speaker
Speaker Power (W RMS)135.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)20.0
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)20
Highest frequency (Hz)17000
CLARK SYNTHESIS DILUVIO AQ339-100 Aquasonic Underwater Speaker 135W 4 Ohm 20Hz-17kHz
The Diluvio™ AQ339-100 underwater speaker from Clark Synthesis is the only underwater speaker in the world to offer full frequency and...
