WBT-0708Cu Gold Plated Copper Speaker Terminals (Set x4)
The result of the latest generation of development by WBT, the 0708Cu speaker terminals feature pure copper conductors and a gold-plated plating. Thanks to the separation of the transmission line from the mechanical chassis, it is now possible to use high-quality materials for each component of these terminal blocks. Although the best electrical conductor, copper or silver do have some mechanical limitations, which WBT has overcome by using high-performance plastics.
Reference : 6409
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 12-05-2026.
Speaker terminals WBT-0708Cu
What's more, the core of this new terminal block is made of a single piece, thus avoiding any unnecessary resistance. The signal conductor is protected by a fiberglass matrix reinforced with mineral plastic, and covered by a non-magnetic steel body. A complementary elastomer damping system drastically limits the vibrations transmitted to the conductor. The microphonic effect is thus greatly reduced, to the benefit of the precision of the sound signal transmitted.
xxx
Product typeSpeaker terminals
Contact materialCopper
Plating materialGold
CompatibilityBanana 4mm
Spade 6 / 8mm
Bare wire
Max cable conductor section4mm² (11AWG)
Internal connectionSolder lug or 6.3mm flat lug
Max panel thickness6.5mm
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)6.5
Accepts Banana PlugsYes
ConnectorSpeaker terminal
très très bien
Pour upgrader des JBL, en comparaison avec l'original puis d'autres borniers 8mm en ofc plaqué argent, les borniers WBT sont très très bien, pas d'effet bouchon ou de voile sur une partie du spectre qui est étendu, ça descend vraiment bas et monte bien haut , la quantité de matière utilisé est cohérent avec les sections de câble HP généralement utilisé.
Très content de ce produit, vraiment.
Merci à Audiophonics pour la passion commune, bravo à l'équipe.
This review has been posted for WBT-0708Cu Gold Plated Copper Speaker Terminals (Set x4)
The result of the latest generation of development by WBT, the 0708Cu speaker terminals feature pure copper conductors and a gold-plated plating....
