Start-up EVO - RaspDac - RaspTouch - RaspDac Mini with a pre-configured image
Posté le 2018-11-20 Tutorials & Guides, Volumio, Open Source Solutions, Tutos 88379
Starting guide for RaspDAC / RaspTOUCH / RaspDAC Mini
With pre-configured image
The RaspDAC / RaspTOUCH / RaspDAC Mini products include features that require modifications to standard open source reading distributions. To make installation easier and more accessible to as many people as possible, we regularly provide images dedicated to these products, allowing you to enjoy all the features without typing command lines (SSH).
You will find below a list of images available for the different products we sell. However, we cannot offer all distributions for all available products and configurations. It is also possible that these images may not always be the latest version of the software, but they have the advantage of being immediately functional.
If have any hesitation about which distribution is the best for you, we suggest you read this article which details the features found in each system.
Following images are made for I-Sabre DAC ES9028/38, if you are using ES9023 or compatible you have to change DAC driver for RPI-DAC standard one.
Win32 Disk Imager download
Win32 Disk Imager is a software that allows you to write on an SD card a pre-established image like the ones we provide or the ones you can download from the websites of the different distributions.
Download Win32 Disk Imager
Once downloaded and installed, launch this application. You arrive on a window of this type:
Win32 Disk Imager
  1. Point to the drive letter corresponding to the Micro SD card you want to use.
  2. Click on the folder to search for the image in the directory in which you unzipped it (.img file).
  3. After checking that the letter matches the Micro SD, all you have to do is click on the Write button.
The "Write Successfull" message is displayed when the operation is completed. The card is now ready to be inserted into your network drive.
On Windows, your computer will try to mount (read) the SD card you just wrote. This operation will fail since your SD card now has Linux-type partitions. Because of this, Windows will suggest you format the SD card. Refuse any offer to format your newly written card but do not worry : this behaviour is perfectly normal.
RaspDAC Mini LCD Images
Please note, the images presented in the section below concern the  RaspDac Mini LCD version (from March 2021).
They are not suitable for the RaspDac Mini with an OLED screen (monochrome).
For distributions adapted to the RaspDac Mini first of the name, go to the section dedicated to this device a little further down on this same page..
You can find the source code used to build the releases by following this link.
Volumio Volumio 3.601
Volumio 3.601
    • ES9038 driver for hardware volume (kernel native)
    • LCD Display support (Volumio version)
    • LIRC pre-configured
    • Switch filters via remote
Moode Moode V8.1.2
Moode 8.1.2
  • Driver ES9038 for hardware volume
  • LCD display Support (moOde version)
Evo Sabre DAC Images
DietPi picCore Player Evo Sabre 8.2.0
piCore Player (32bit)
  • Driver I-Sabre 9028/38
  • Script oled#2 Audiophonics
  • LIRC pré-configuré
Volumio Moode V8.2.4 EVO SABRE IMAGE
Moode
  • Script OLED display pre-configured (nodejs)
RaspTOUCH Images
Additional functions necessary for the operation of a RaspTOUCH:
  • Graphic layer required to get a return on the screen.
  • Power management function for the power button.
  • ES9038 versions require a special driver to take advantage of the hardware volume.
Volumio MOODE 7.0.1 RaspTOUCH Image
Moode Audio 7.0.1
  • Graphical touch interface
  • Power management script Pi4 compatible
Volumio Volumio 3+ RaspTOUCH tutorial (github)
Volumio 3+
  • PI4 Support
  • Virtual Keyboard
  • Support Myvolumio
Roon Roon RaspTOUCH Image
Roon Bridge + Web Controller
  • I-Sabre ES9028/38 driver with hardware volume
  • Roon Bridge with web controller installed
  • Power management PI-SPC
  • Virtual Keyboard for Chromium
RaspDAC Mini Images
Additional functions necessary for the operation of a RaspDAC Mini:
  • Script for display on the OLED SPI screen.
  • Infrared reception.
Moode Audio R73
Image moode RaspDAC Mini
Moode Audio 7.4.0
  • RPI4 support
    (kernel native)
  • DAC Plugin page (Filters & Input)
  • New simplified 1 page Display
  • LIRC pre-configured for the remote control supplied in the kit
DietPi DietPI V6.19 LMS LIRC OLED Image
DietPi
  • Display script on the OLED SPI screen
  • Pre-installed LMS with Qobuz plugin, DSD128, UPnP / DLNA playback, hardware volume
  • Pre-installed Samba (access to a NAS)
Logo Rune Audio
For Raspberry Pi 3 version only.
Rune AUdio 0.5 RaspDAC Mini IMAGE
RuneAudio 0.5 Beta
  • Alsamixer WEB UI for filters / Inputs ( :8080)
  • Display script on the OLED SPI screen + Dac Menu
Volumio GitHub Volumio RaspDAC Mini
Volumio 3+
  • Please visit our repo GitHub to make an installation through SSH.
RaspDAC Images
Additional functions necessary for the operation of a RaspDAC:
  • Both HiFiBerry and ES9038 driver natively availble in distributions.
  • Script for display on the OLED screen.
  • Infrared reception if installed.
Volumio
Moode 5.3 RaspDAC Image
Moode 5.3
  • ES9038 Driver for hardware volume
  • Moode DAC Plugin (Filters and Input)
  • RaspDacDisplay script for OLED
  • LIRC pre-configured for Audiophonics 9294 remote control
Volumio Volumio RaspDAC Image
Volumio 2.861
  • HiFiberry base driver, change if needed in webUI
DietPi DietPi 20181128 RaspDAC LMS Image
DietPi
  • I-Sabre 9028/38 Driver
  • PydPiper for OLED display management with LMS
  • PI-SPC power management
  • Pre-installed LMS with Qobuz plugin and hardware volume
  • Samba pre-installed (NAS Connection)
Required to configure the MAC address of the board in 2 files. See text file provided with the image.
83 Commentaires
Laisser un commentaire
  • Christophe Zabawinski
    Christophe Zabawinski 2024-03-08
    Bonjour,
    Je viens de voir que vous aviez posté l'image de piCorePlayer pour Evo Sabre DAC. Je vous remercie beaucoup, je l'attendais depuis un moment :).
    Je vais donc l'installer mais je me demandais comment cela se passe en cas de mise à jour de pCP . Pourrais-je l'updater à partir de la mise à jour officielle ou devrais-je attendre que vous développiez une version ad-hoc Audiophonics ?
    Merci par avance de votre retour
    • Audiophonics Team
      Audiophonics Team 2024-03-08
      Bonjour, les mises à jour de version mineures peuvent être appliquées sans problème. Les versions majeures demanderont probablement une réinstallation complète en cas de changement du kernel ou d'une librairie importante (glibc), le cas échéant je mettrai une image de référence à jour en ligne qui pourra être utilisée jusqu'au prochain changement de version majeure.
        Merci beaucoup de votre réponse
  • Philippe Jung
    Philippe Jung 2024-01-23
    Bonjour,
    j'ai un raspdac mini monochrome du 05/2020 monté avec un PI 4 B.
    (https://www.audiophonics.fr/fr/lecteurs-reseau-open-source/audiophonics-raspdac-mini-kit-diy-lecteur-reseau-pour-raspberry-pi-3-dac-es9038q2m-p-13300.html).
    Est-il possible d'upgrader vers la version MINI LCD couleur en changeant P3 (l'ecran, P2 ne semble pas necessaire ?) et le software approprié ?
    Si oui, peux t'on acheter en piece detachees P3 (et P2 ?) ou avoir la reference de l'ecran P3
    lcd couleur 320x240 SPI ?
    Merci.
    • Audiophonics Team
      Audiophonics Team 2024-01-23
      Bonjour,
      Malheureusement l'écran LCD est plus large que l'écran OLED. Sur votre carte, la diode du récepteur IR bloque son installation et ne permet pas d'intégrer un écran plus large.
      Par ailleurs nous ne proposons pas l'écran LCD en vente seule (la référence est ILI9341 SPI TFT 240x320 2.4 pouces, pin RST branché sur GPIO24 et pin DC sur GPIO27).
      Je sais que certains autres utilisateurs ayant souhaité améliorer cet écran ont retiré la nappe d'extension de la carte SD pour faire passer un cordon HDMI à la place et y relier un écran large classique. C'est une solution un peu "overkill" mais qui a le mérite de nécessiter peu de configuration et ouvre également d'autres possibilités (tactile).
  • Wolfgang Karp
    Wolfgang Karp 2023-12-06
    Bonjour
    Nous sommes fin 2023 et dans trois semaines nous approcherons de 2024. Le Raspberry Pi 4 a désormais le Pi 5 comme successeur, mais là nous vivons toujours en 2022. Ma question est donc de savoir si Audiophonics supportera le Raspberry Pi 5 ?
    Salutations Wolfgang
    • Audiophonics Team
      Audiophonics Team 2023-12-07
      Bonjour. Nous allons bien entendu faire le nécessaire pour que nos modules & logiciels encore présents sur le marché s'adaptent (dans la mesure du possible) à cette nouvelle itération du Pi. Cela se fera cependant avec un délai conséquent afin d'éviter de retomber dans le piège du Pi4 révision 1.5 où nous avons été contraints de redévelopper beaucoup de choses en parallèle avec les distributions communes d'OS orienté streamer pour gérer les breaking changes tardifs.
      En revanche, si votre question concerne plutôt la possibilité que nous fabriquions un nouveau streamer ou kit avec boitier basé exclusivement sur le Pi 5, ce projet n'est pas à l'ordre du jour.
      Si vous avez des questions sur un produit en particulier, n'hésitez pas à répondre directement à ce message.
  • Sylvain HELAINE
    Sylvain HELAINE 2022-08-08
    Bonjour,
    Je viens d'acheter un Rasptouch I-Sabre ES9038Q2M 32bit 384kHz DSD128.
    J'ai chargé l'image version 2.852 de Volumio fournie sur cette page. Le rasptouch ne boot pas. Je n'ai pas d'affichage sur l'écran du Rasptouch mais sur un autre écran seulement si je le connecte via la prise HDMI. Le boot tourne en boucle avec un problème sur le fichier start4.elf.
    J'ai essayé la version d'image sur le site de Volumio en utilisant les login et password par défaut. Volumio se lance mais en ligne de commande seulement. Je ne suis pas expert dans ce domaine et cela nécessite un clavier connecté au Rasptouch.
    J'ai récupéré du coup les informations de boot de cette image pour les remplacer sur la version 2.852. Volumio se lance cette fois-ci avec un affichage sur l'écran du Rasptouch mais la fonction tactile ne fonctionne pas et Volumio semble instable.
    Pouvez vous m'indiquer s'il vous plait quels seraient les fichiers du dossier boot à garder et ceux à remplacer?
    En vous remerciant pour toute aide que vous pourrez m'apporter.
    Cordialement
    • Audiophonics Team
      Audiophonics Team 2022-08-17
      Bonjour,
      L'image fournie ici est datée. La méthode récente et simple pour cet appareil est la suivante : bootez un Volumio3 usine, installez le plugin System_Hardware - Touch Display depuis l'interface web classique Volumio. L'écran fonctionnera normalement sans avoir besoin de modifier quelconque fichier.
  • Bruno Frydman
    Bruno Frydman 2022-04-15
    Bonjour,
    En Juillet 2019 j'ai acheté ce AUDIOPHONICS RASPDAC MINI Kit DIY Lecteur Réseau pour Raspberry Pi 3 & DAC ES9038Q2M et j'en ai été très content.
    L'application fonctionne très bien sous Volumio avec les mises à jour mais j'ai perdu toute image sur l'écran LED. Je fonctionne avec la version système 2.882 du 24/04/21. J'ai cherché sur votre site et fait des expérience de flash de diverses versions sans succès. Comment retrouver la montre et les infos sur la LED? Merci.
    • Audiophonics Team
      Audiophonics Team 2022-04-28
      Bonjour,
      Techniquement, après mise à jour vous n'êtes plus sur du 2.882.
      Pour utiliser Volumio 3 sur la version OLED, vous devez flasher une image Volumio de base (trouvable ici : https://volumio.com/en/get-started/#download ), vous y connecter en SSH et suivre ces instructions : https://github.com/audiophonics/RaspDacMini/tree/volumio.
      Une fois cette manœuvre effectuée, vous pourrez faire les mises à jour Volumio 3 normalement.
  • Clément Détré
    Clément Détré 2022-04-11
    Bonjour,
    Je possède une image de Volumio 3 sur mon Raspdac mini écran OLED. Seriez-vous en mesure de me dire comment varier la luminosité par défaut de l'afficheur OLED ?
    Merci d'avance.
    • Audiophonics Team
      Bonjour,
      Cette option n'est effectivement plus accessible depuis l'interface web. Vous pouvez la configurer en SSH en tapant la commande
      rdmoled 80
      (remplacez 80 par un nombre compris entre 0 et 254 )
      Cette configuration est persistante entre deux redémarrage.
  • Laurent Le Portz
    Laurent Le Portz 2021-12-25
    Bonjour:
    Merci pour l'update Evo_2021_12_13_volumio_3173 .rar pour l'EVO. Hélas, Volumio pas content. Le lancement via addresse IP indique ' cd-controller plugin. Le démarrage de ce plugin a échoué...'
    Ensuite mode dégradé... tous mes settings/favoris perdus, l'écran de droite indique juste l'heure quand il n'est pas noir, pas possible de mettre des plugins 'Une erreur est survenue lors de l'installation du plugin Error: Error creating folder: Error: ENOSPC: no space left on device, mkdir '/data/temp', impossible de monter mon NAS (même ENOSPC erreur)
    Une soluce pour moi (à part revenir à la version Volumio 2 :( )?
    Merci d'avance
    • Audiophonics Team
      Audiophonics Team 2022-01-04
      Bonjour,
      La mise à jour V2 vers V3 écrase toute config précédente, aucune solution autre qu'un backup préalable n'existe de ce côté là.
      Le système des plugins a largement évolué sur la V3 : compte (gratuit possible) obligatoire.
      Par ailleurs beaucoup des plugins V2 ne sont pas encore fonctionnel sur V3.
      Enfin Il est recommandé (pour ne pas dire obligatoire) d'écraser directement votre carte SD avec la nouvelle image plutôt que de faire une maj depuis l'interface Volumio.
      A la lecture des messages d'erreurs que vous me partagez, je pense que le problème est au choix (plusieurs bonnes réponses possibles):
      - Vous avez fait une maj logicielle depuis l'interface web au lieu d'écraser la carte SD.
      - Votre carte SD est corrompue (système readonly).
      - Une image système pour un autre appareil a été utilisée par erreur ou bien le système a été modifié entre temps (typiquement installations en SSH après mise en route).
      - Un appareil non reconnu est branché sur le pi et bloque l'initialisation de l'OS.
      Tous ces cas de figurent devraient être résolus par la même manœuvre : formatter proprement la carte SD, la reflasher avec l'image système contenue dans l'archive Evo_2021_12_13_volumio_3173 .rar, débrancher tous les périphériques du EVO puis reconfigurer vos sources depuis l'interface web.
      Si besoin l'équipe Volumio a fait une excellente FAQ ici : https://community.volumio.org/t/volumio-3-issues-hints-and-solutions/51707
      • Laurent Le Portz
        Laurent Le Portz 2022-01-08
        Magique! Comme sur des roulettes... Promis, j'essayerai de résister à l'upgrade via l'interface web et j'attendrai le votre :)
        Encore merci :)
        • Audiophonics Team
          Audiophonics Team 2022-01-11
          En dehors des changements de version majeures ( Volumio2 vers Volumio3 ) vous pouvez faire les mises à jour système depuis l'interface Volumio sans crainte de casser quoique ce soit. Tant que le numéro de version est 3.xxx tout se passera bien.
  • Gábor Ábrahám
    Gábor Ábrahám 2021-12-19
    Hi,
    HW: Raspberry Pi 4 + ALLO KALI Reclocker + Audiophonics I-SABRE Es9028Q2M DAC
    SW: Volumio 3.173 (Evo_2021_12_13_volumio_3173)
    The volume is very low and independent from volume control settings of Volumio.
    Thank you in advance,
    Gábor
    • Audiophonics Team
      Audiophonics Team 2021-12-20
      You need to allow MPD sources to control the volume in the UI / playback settings if you want to use the app instead of the remote to change volume.
      • Gábor Ábrahám
        Gábor Ábrahám 2021-12-21
        MDP enabled.
        if LiveLog is enabled when I change the volume, I see this error message:
        info: CoreCommandRouter::volumioPushState
        error: Cannot set ALSA Volume: Error: Alsa Mixer Error: amixer: Invalid command!
        info: VolumeController::SetAlsaVolume39
        info: CoreStateMachine::pushState
        • Audiophonics Team
          Audiophonics Team 2021-12-22
          I'm sorry I misread your initial comment. Why are you using a EVO Release on a your Pi build ? This software image you are using is pre-packed with remote & display drivers that continuously try to write to the pi's GPIO and it's not hard to imagine this causing issues with the reclocker.
          The hardware you are using does not require a modified Volumio image. Just download the regular Volumio distribution, set your ES90x8 DAC in the first boot wizard and you should good to go.
  • Jens Schneider
    Jens Schneider 2021-12-10
    Is there a Volumio 3 Update for the Evo DAC? The Volumio Update ( now updates to 3) has kicked my whole configuration.
    Regards
    Jens
    ( are the packages on github version 3 ready?)
    • Audiophonics Team
      Audiophonics Team 2021-12-13
      Hi, there is now :)
      But the github is not up to date yet.
  • Allan THIERRY
    Allan THIERRY 2021-12-09
    Bonjour la Team Audiohonics,
    J'ai mis sans regarder à jour mon RaspDac Mini à jour avec la version 3 de Volumio et je me retrouve sans son et sans image sur l'écran... Je viens de voir qu'il y avait une image de la version 3 seulement pour le mini LCD, pouvez vous mettre à dispo celle pour le Oled?
    En vous remerciant.
    • Audiophonics Team
      Audiophonics Team 2021-12-09
      Hello,
      Je ne pense pas avoir le temps de m'occuper du mini OLED avant lundi, mais il y aura effectivement une image v3 pour ce dernier.
  • Vano Peter
    Vano Peter 2021-12-08
    Bonjour, depuis la dernière mise à jour de Volumio 3, le LCD ne fonctionne plus sur RaspDac. Existe-t-il une solution ? Merci d'avance.
    • Audiophonics Team
      Audiophonics Team 2021-12-08
      Bonjour,
      Je finis de tester que tout le hardware fonctionne bien sur V3. Une image à jour sera disponible demain.
  • Sebastien De poortere
    Sebastien De poortere 2021-11-23
    Bonjour, depuis la dernière mise a jour de moOde audio 7.6.0 j'ai perdu l'affichage plein écran sur mon RaspDAC Mini LCD !
    es que vous avez prévu de mettre à jour l'image préconfiguré ou y a t'il un moyen de rétablir les réglages ?
    merci pour votre aide
    • Audiophonics Team
      Audiophonics Team 2021-11-24
      Bonjour,
      je n'ai pas encore eu le temps de regarder les dernières versions de moOde mais j'ai laissé des options d'autoréparation dans le système du LCD exactement pour ce genre de cas. Voici comment les utiliser.
      Ouvrez un navigateur web et allez sur l'url suivante :
      http://moode-lcd:4150
      si vous n'y arrivez pas ou que vous êtes sur un téléphone android utilisez plutôt :
      http://192.168.xx.xx:4150 (en remplaçant les xx par l'adresse ipv4 actuelle de votre RDM).
      Cliquez sur le bouton "Reinstall LCD driver" et attendez quelques minutes.
      Cliquez ensuite sur "Auto-configure" dans la même page.
      Si l'écran revient, redémarrez pour confirmer que tout est rentré dans l'ordre.
      Si l'écran ne revient pas convenablement ou qu'un redémarrage recause des problèmes, cela signifie que je dois mettre à jour mon script d'installation.
      N'hésitez pas à me répondre ici pour me faire savoir le résultat de l'opération. J'ai encore 2 ou trois items sur ma todo-list avant de mettre à jour notre version moOde du RDMLCD mais si vous êtes sans écran je remonterai l'ordre des priorités pour ne pas vous laisser sur la touche.
      EDIT : vérifiez aussi que l'option System Config / Local Display est toujours activée dans l'interface moOde.
  • christian cheignon
    christian cheignon 2021-11-22
    Bonjour
    J'ai un rasptouch qui fonctionne avec volumio. Je commence à tester voumio3 qui est en rc1. Pensez vous mettre à jour le plugin audiophonicsonoff pour volumio3.
    Cordialement
    Christian
    • Audiophonics Team
      Audiophonics Team 2021-11-26
      Bonjour,
      Je n'ai pas la main sur le plugins Volumio. Ceux-ci sont des ports réalisés par des utilisateurs de la communauté qui maitrisent bien mieux que nous les fonctionnements spécifiques à cet OS. En revanche, nous allons naturellement vouloir faire tourner nos gestionnaires d'alimentation sous Volumio3 mais d'abord, la prudence (et le manque de temps) nous dictent d'attendre qu'une version stable et définitive soit publiée et il nous faudra par la suite demander à ce que les plugins soient mis à jours par les auteurs des ports. En d'autres termes, si l'utilisation de plugin est votre seule option, ce ne sera pas pour tout de suite.
      En revanche, si vous êtes assez à l'aise pour éditer quelques fichiers de configuration vous pouvez invoquer directement un dtoverlay et avoir 90% des fonctionnalités du gestionnaire d'alimentation sans utiliser de plugin ni installer quoique ce soit. Ajoutez simplement ces deux lignes dans /boot/userconfig.txt :
      dtoverlay=gpio-poweroff,gpiopin=22,active_low
      dtoverlay=gpio-shutdown,gpio_pin=17,active_low=0,gpio_pull=down
      et le gestionnaire d'alimentation devrait être fonctionnel au prochain reboot. Cette méthode marche à peu près sur n'importe quel système tournant sur Raspberry Pi (mais ne réagit pas au reboot / poweroff initié depuis une autre source que le bouton on/off). Si vous désirez upgrader sur V3 tout de suite, cette option peut vous permettre d'utiliser le gestionnaire d'alimentation sans attendre de plugin.
        christian cheignon 2021-11-28
        Bonsoir
        Merci pour votre retour. Le bouton d'arrêt est maintenant fonctionnel.
        Cordialement
        Christian
  • nguyen xuan hung
    nguyen xuan hung 2021-11-16
    Hello Audiophonics Team.
    Currently I am using RaspDAC Mini oled kit together with Raspdacmini_2021_10_05_volumio_2.909. But because I made another case, the oled screen is 180 degrees upside down. Because it's CNC, I can't rotate it. Can you show me how to fix the inner statement!. Thanks
    • Audiophonics Team
      Audiophonics Team 2021-11-16
      Hello,
      If you can SSH or FTP into your system, edit this file : /home/pi/RaspDacMini/volumio/oled/index.js
      go to line 23 and change " flip : true," into "flip : false,".
      Then reboot.
    Christophe Zabawinski 2021-11-14
    Bonjour,
    Fan de LMS, j'utilise votre image DietPi pour mon EVO-Sabre. Tout se passe pour le mieux sauf pour l'aspect "File server". Il m'est impossible de mettre en place Samba ou ProFTPD via la partie "File Server" de "DietPi-Software"
    Dès que je choisis le protocole désiré et lance "Install", j’ai le message que j'ai copie ci-dessous qui s'affiche et ne peux aller plus loin. Merci de votre aide
    APT update │
    │ - Command: apt-get -q update │
    │ - Exit code: 100 │
    │ - DietPi version: v6.31.2 (MichaIng/master) | HW_MODEL: 4 | HW_ARCH: 2 | │
    │ DISTRO: 5 │
    │ - Image creator: DietPi Core Team │
    │ - Pre-image: Raspbian Lite │
    │ - Error log: │
    │ Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB] │
    │ Get:2 https://archive.raspberrypi.org/debian buster InRelease [32.6 kB] │
    │ Reading package lists... │
    │ E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' │
    │ changed its 'Suite' value from 'stable' to 'oldstable' │
    │ E: Repository 'https://archive.raspberrypi.org/debian buster InRelease' │
    │ changed its 'Suite' value from 'testing' to 'oldstable' │
    │ Retry : Re-run the last command that failed ↑ │
    │ DietPi-Config : Edit network, APT/NTP mirror settings etc
    • Audiophonics Team
      Bonjour, tentez d'ajouter ce flag à votre commande : "apt-get update --allow-releaseinfo-change"
        Christophe Zabawinski 2021-11-17
        Bonjour,
        Merci de votre aide. Cela a très bien fonctionné.
  • Todd Gold
    Todd Gold 2021-11-11
    Bonjour,
    Existe-t-il un package Volumio ou Moode pour le DAC Sabre qui fonctionnera avec une Asus Tinker Board (2S) ?
    Est-il possible d'obtenir séparément les pilotes Sabre DAC et les scripts LCD ?
    Merci d'avance pour votre temps et votre aide.
    Merci,
    TJ
    • Audiophonics Team
      Bonjour,
      Je n'ai malheureusement aucune expérience sur les Asus Tinker Board et il me semble hautement improbable d'y déployer quoique ce soit à moyen / court terme.
      Toutefois vous pourrez trouver les sources du pilote assurant l'interface SABRE / ALSA ici : https://github.com/audiophonics/I-Sabre_9038Q2M
      Le cœur du pilote RaspDacMiniLCD utilise la (fabuleuse) librairie fbcp-ili9341 : https://github.com/juj/fbcp-ili9341
      Ce composant suffit déjà à envoyer l'affichage natif Volumio (avec son plugin touch) ou le ​Local Display de moOde vers le LCD (mais sacrifie la sortie HDMI indépendante).
      Toutes les configs de build et scripts que j'utilise pour obtenir un affichage spécifique sont trouvables ici : https://github.com/audiophonics/RaspDacMinilcd
      Désolé de ne pas pouvoir vous proposer une solution plus clé en main mais j'espère que vous trouverez quelques pistes avec ces éléments
      • Todd Gold
        Todd Gold 2021-11-18
        C'est une merveilleuse information. Je suis sûr que je peux pirater quelque chose ensemble. Je vous ferai savoir si je vais avec le Tinker Board (si vous êtes intéressé). Merci beaucoup. Bon piratage!
  • Alexis Boucher
    Alexis Boucher 2021-10-24
    Bonjour,
    Suite au problème de certificats chez Volumio, empêchant la connexion aux services Tidal ou Qobbuz, j’ai voulu faire la mise à de l’image Volumio 2.909 que vous proposez, vers la version 2.917. Mais cette mise a jour fait planter mon système. J’ai reflashé plusieurs fois ma SD avec votre image pour re tenter la mise jour, mais sans succès.
    Du coup j’utilise l’image officielle de Volumio, mais impossible de faire fonctionner l’écran de droite malgré l’installation du packet disponible sur https://github.com/audiophonics/Evo_Sabre.
    Ça affiche une erreur de dépendance sur #Oled2. L’installation se termine et j’aime accès à Volumio.local:4150.
    Ai je oublié d’installer quelque chose ?
    • Audiophonics Team
      Audiophonics Team 2021-10-27
      Bonjour,
      Vous n'avez rien oublié. J'ai négligé une section du script d'installation de l'écran lors de ma dernière mise à jour des sources GitHub. J'ai rectifié lesdites sources et je vais publier une nouvelle image complète d'ici la fin de semaine. Encore désolé.
  • Hen Dekker
    Hen Dekker 2021-08-18
    Sir ,
    When do you have an update moodeaudio 7.3 for the the raspdac and the old minikit ?
    It seems that you stopped update them !!!
    Hen
    • Hen Dekker
      Hen Dekker 2021-09-01
      I have the old mini kit and the raspdac
      So with this toolkit you can upgrade the minikit with oled and lcd to moode 7.3 ?
      Does the tool work also with the raspdac?
      Thanks
    • Audiophonics Team
      Audiophonics Team 2021-08-26
      I just uploaded a new moOde image for the RaspDac Mini OLED.
      I also updated its github repository ( http://github.com/audiophonics/RaspDacMini ) so people can now build / repair their own customized images from a native moOde / Volumio distribution if I take too much time.
      We however do not build new versions for the even older Raspdac first series anymore because all features can now be easily enabled from a default non-customized image.
      - On Volumio, everything can be configured from the default web interface (selecting your output in the wizard & installing the OnOff plugin)
      - Same on moOde pick your output in the interface and follow those steps : http://github.com/audiophonics/Raspberry-pwr-management .
  • Nuno Beirao
    Nuno Beirao 2021-06-18
    Est-ce qu'il serai possible d'avoir un tutoriel en expliquant comment faire l'actualization de moode pour l'Evo Sabre, RPI 4 ?
    • Audiophonics Team
      Bonjour,
      Il est délicat de faire un tutoriel gérant tous les cas de figure car deux mises à jours système ne vont jamais affecter les mêmes éléments de configuration.
      De façon générale, je vous conseille de faire une sauvegarde de sécurité puis de faire la mise à jour système normalement via l'interface web. En temps normal, les updates système n'affectent pas nos modifications.
      Un conflit est bien entendu théoriquement toujours possible. Si vous constatez un disfonctionnement après une mise à jour, je vous invite à suivre les instructions sur le github dédié au EVO ( https://github.com/audiophonics/Evo_Sabre ) pour réinstaller / reconfigurer le software de prise en charge de l'écran / télécommande... etc. Si cela ne règle toujours pas le problème, appliquez la même manipulation sur une image système native (non-customisée).
      Enfin, si aucune de ces solutions ne règle le problème, contactez-nous directement. Nous trouverons une solution et mettrons à jour les instructions.
  • Rostislaw Krütschkow
    Rostislaw Krütschkow 2021-05-28
    Hello, I've run into an issue with my new Audiophonics RaspDAC Mini LCD. I've updated to Moode 7.21 and now my LCD screen s not showing the coverview anymore. Does anyone have an idea what the update might have changed, and how to fix it?
    • Audiophonics Team
      Audiophonics Team 2021-07-30
      Hi,
      There is an option for automatic reconfiguration of the display for any case like this.
      Try opening the web interface on port 4150 by going to http://moode-lcd:4150 or http://192.168.xx.xx:4150 if you are on android (don't forget to use your RDM actual IP in that case) and hit the Auto-configure button. Everything should go back to normal.
      • AP DIXIT
        AP DIXIT 2021-08-15
        Hi,
        Over the weekend, I managed to update OLED-2 to work with Moode V7.3 following instructions provided on Audiophonics/GitHub page via SSH commands followed by backing up the microSD card into a IMG file. Works perfect.
        Merci.
  • Arnaud MAURISSET
    Arnaud MAURISSET 2021-04-10
    Bonjour,
    Est-ce possible d'avoir une image préconfigurée de Dietpi pour rasptouch (RPI3B+).
    Ou sinon comment avoir les commandes à l'écran comme avec Volumio ou picoreplayer? J'ai posé la question sur le forum, mais pas de réponse: http://forum.audiophonics.fr/viewtopic.php?f=12&t=3200
    En fait je teste Dietpi, car j'ai un problème avec Picore player, si vous pouvez regarder sur le forum ce serait sympa:
    http://forum.audiophonics.fr/viewtopic.php?f=12&t=3126
    Merci d'avance
    • Audiophonics Team
      Audiophonics Team 2021-04-14
      Bonjour,
      Nous n'avons pas prévu de créer de nouvelles images pour les systèmes pi3 (nous maintenons toujours les systèmes déjà supportés toutefois).
      Vous pouvez installer Jivelite sur Dietpi afin d'avoir un retour graphique avec support tactile sur l'écran d'un RaspTouch, mais de mémoire ce programme ne figure pas dans les listes d'applications DietPi et doit être compilé manuellement - ce qui nécessite quelques compétences techniques.
  • edouard rivault
    edouard rivault 2021-03-18
    Bonjour,
    la version Volumio 2.852 EVO SABRE IMAGE estelle celle qui permet d'avoir le second afficheur avec le AUDIOPHONICS EVO-SABRE DAC Symétrique 2x ES9038Q2M USB RPI SPDIF BT / XLR RCA ?
    En effet jorsque j'avais acquis celui-ci, elle n'etait pas encore disponible et mon second afficheur n'est donc pas encore en marche.
    Merci d'avance. Cordialement
    • Audiophonics Team
      Audiophonics Team 2021-03-19
      Bonjour,
      Toutes les images actuellement proposées pour le EVO Sabre prennent en charge le second afficheur (écran OLED de droite). Vous êtes effectivement au bon endroit.
  • Jean-Philippe Chaffiol
    Jean-Philippe Chaffiol 2021-02-06
    Bonjour et merci poir vôtre travail. Je me renseigne de plus en plus sur la hi-fi 2.0 et je m attaque a un nouveau sujet. L evo sabre intègre 7 filtres. Est il possible d en intégrer un "fait maison" avec l aide d une calibration micro? Je pense a une solution faite avec le logiciel rew. Est ce faisable?
    Merci de vôtre aide.
    • Audiophonics Team
      Audiophonics Team 2021-02-16
      Bonjour,
      Les options sélectionnables dans la board EVO vous permettent de choisir un filtre de reconstruction pour votre DAC. Celles-ci sont intégrées directement au hardware et ne peuvent pas être modifiées.
      Vous semblez plutôt rechercher une solution de correction acoustique / DSP, ce qui est possible sous Volumio (plugin brutefir). Plus d'infos ici : https://www.audiosciencereview.com/forum/index.php?threads/how-to-make-room-eq-with-volumio.5585/
  • Laurent Canu
    Laurent Canu 2021-01-24
    Bonjour,
    je viens de faire l'acquisition d'un raspdac mini PI4 avec carte SD et image Volumio. Je découvre l'utilisation et le son splendide de ce lecteur. je me pose cependant quelques questions restées sans réponses malgré mes recherches.
    Comment arrêter ce lecteur proprement ? Je dois réinstaller l'image de Volumio à chaque fois que j' éteins mon installation!
    J'ai voulu essayer les images de moode et dietpi, mais le Pi 4 ne semble pas booter dessus. Ces images sont elles compatibles avec Pi4 ?
    Merci pour vos réponses
    Cordialement
    • Audiophonics Team
      Audiophonics Team 2021-02-05
      Bonjour,
      Vous trouverez une option pour éteindre le Pi en douceur directement dans les paramètres de l'interface web Volumio.
  • Jonathan GALLON
    Jonathan GALLON 2020-11-12
    Bonjour,
    Existe t il une documentation sur les changements que vous appliquez sur les images pour supporter le bouton on/off et l'ecran ?
    Je voudrais tester moode avec une image plus recente (pour un raspdac) mais je ne trouve pas de documentation pour faire les faires marcher.
    Merci d'avance
    • Audiophonics Team
      Audiophonics Team 2020-11-17
      Bonjour,
      L'essentiel sur le power management est disponible sur notre github ( https://github.com/audiophonics/Raspberry-pwr-management ).
      Le support d'écran est effectué en python avec la librairie LUMA lorsque la distribution le permet (ou LMSMonitor dans les environnements LMS)
  • ardizzone dario
    ardizzone dario 2020-10-17
    good morning,
    I am a happy owner of a RaspTouch I-Saber ES9028Q2M KALI - Streamer Touch with Volume Control
    updated to the latest available version of volumio (2668), I would like to know when an update will be released.
    Thank you
    • Audiophonics Team
      Hi,
      A new version is available right now.
  • Vincent Perrin
    Vincent Perrin 2020-08-17
    Bonjour,
    Pouvez-vous m'indiquer si l'image Volumio 2.668 pour Rasptouch intègre le plugin QOBUZ.
    Par avance merci.
    • Audiophonics Team
      Audiophonics Team 2020-08-28
      Le plugin Qobuz nécessite un compte MyVolumio (facultatif) pouvant être bloquant pour les utilisateurs ne disposant pas de ce type d'abonnement. Aussi, ce dernier n'est pas installé par défaut, mais peut-être installé manuellement.
  • gilles bresse
    gilles bresse 2019-11-28
    j'ai le RASPDAC LTE I-SABRE ES9038Q2M , telechargé sur le lien audiophonic les fichiers megaupload ,
    j'ai donc 4 versions devolumio2
    essayé la version 2.619 mais ca me demande login et password ! donc je bloque ;
    j'ai essayé d,autres versions dans le dossier téléchargé et pareil , que faire?
  • Ales Strmsek
    Ales Strmsek 2019-10-09
    Hello. Installed your latest modified Moode audio image, version 6.2.1 for RASPDAC MINI, but MPD can't find any music from my NAS device. Everything works fine with your previous version and also there are no issues with original Moode audio images , including the latest 6.3. Any suggestions ? Thanks and best regards
    • Audiophonics Team
      Audiophonics Team 2019-10-09
      Hello,
      Can you contact us directly via our contact form please: https://www.audiophonics.fr/contact-us
      We will help you as best we can.
  • Ales Strmsek
    Ales Strmsek 2019-10-07
    Hello. I have issue with MPD database. MPD update or regen does not find any music from NAS after your modified latest image for Moodeaudio ver. 6.2.1 was installed. Worked fine with previous version and also with all original Moode versions. Tnx and best regards, Ales
  • Joris Carozzani
    Joris Carozzani 2019-09-25
    La dernière version de volumio disponible hier supporte à nouveau Qobuz, avez vous prévu de l'implémenter pour le raspmini?
    merci
    • Audiophonics Team
      Audiophonics Team 2019-09-26
      Bonjour,
      Nous allons bientôt mettre en ligne la dernière mise à jour Volumio pour nos produits.
      • Enrico I
        Enrico I 2019-09-27
        very good, please let us know as soon as available. Thanks
  • Frederic Lasa
    Frederic Lasa 2019-08-14
    Bonjour, je me demande comment éteindre volumio sur raspdac mini car quand je fait arrêt dans les paramètres de volumio cela coupe volumio et le raspdac mini et je ne peux plus rallumer le raspdac mini car ça flingue le logiciel sur la micro SD, je dois alors réinstaller volumio sur la micro SD pour que le raspdac mini puisse se rallumer. Si vous avez une solution je suis preneur. Merci
  • Guy Maurier
    Guy Maurier 2019-06-28
    Bonjour,
    L'image Roon RaspTouch ne fonctionne pas lorsqu'associée à la carte Allo DigiOne.
    Il semble y avoir un conflit avec les drivers du Power management PI-SPC. Une fois le Power management PI-SPC désinstallé, il est possible de lire de la musique sur le RaspTouch.
    Cependant l'inteface graphique à partir du RaspTouch n'affiche pas ce qui est lu "Now Playing" et ne prend pas en compte la sélectionne faite dans la librairie.
    Merci
    • Audiophonics Team
      Audiophonics Team 2019-07-01
      Bonjour,
      Oui en effet, des pins du GPIO sont communs entre la DigiOne et le contrôleur d'alimentation, le problème que vous rencontrez est malheureusement "normal". Nous allons vous proposer une solution rapidement.
  • Jonathan Rauch
    Jonathan Rauch 2019-04-15
    Bonsoir, la dernière version de volumio2.572 apporte la lecture de cd via un lecteur optique USB.
    Quand pensez vous proposer une image raspdac avec cette version ?
    • Audiophonics Team
      Audiophonics Team 2019-04-17
      Bonjour,
      Prudence, la v2.572 n'est encore qu'un support strictement logiciel pour ladite fonction. A vrai dire, Volumio recommande même de ne pas l'utiliser sur son propre hardware. La question n'est donc pas encore à l'ordre du jour en ce qui nous concerne.
  • Laszlo Voros
    Laszlo Voros 2019-03-15
    Hi!
    The raspdac mini moode image (r43) working fine in upnp/dlna mode. But with squeezelite, the hardware volume control not working.
    In “squeezelit config / other options” need to add “-V Digital” parameter. Now ok, hardware volume working fine.
    Regards,
    Laszlo
    http://i64.tinypic.com/2ryrrli.jpg
  • Joe Souza
    Joe Souza 2019-03-14
    Hello. I apologize for asking in English. I am in the U.S. and I don't speak French (I can speak Spanish, however). I am thinking of purchasing your RaspDAC Kit, but I would really prefer to use Rune Audio instead of Volumio. I know that the version of Rune Audio on their official download page is really old, but they have a much more recent version on their Forum:
    http://www.runeaudio.com/forum/runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532.html
    Is there any chance that you would be able to make the same modifications to this image for the RaspDAC and then post it for download here? Thank you.
    • Audiophonics Team
      Audiophonics Team 2019-03-18
      Hello,
      Thank you for your interest in our RaspDAC.
      Can you contact us directly via our contact form: https://www.audiophonics.fr/contact-us
  • Luca Moiana
    Luca Moiana 2019-03-14
    Hi, suddenly spotify stoped working on my raspdac mini running Volumio.
    I just downloaded and updated Volumio2_20190219_2.555_RaspDacMini .zip
    And I even got lost on Volumio forum
    but no luck, what should I do?
    • Audiophonics Team
      Hello,
  • Michaël Durbecq
    Michaël Durbecq 2019-02-09
    Roon ne s'installe pas correctement une fois le rasptouch démarré. Je reçois après toute la phase d'installation le message : "extension not enabled. please connect to a roon client to enable it."
    Y a t-il une étape que j'ai oubliée ?
    Merci d'avance,
    • Audiophonics Team
      Audiophonics Team 2019-02-22
      Bonjour,
      Voici un tutoriel rapide à propos de Roon sur RaspTouch : https://www.audiophonics.fr/blog-diy-audio/25-roon-rasptouch-connexion-du-web-controller.html
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
