ARYLIC UP2STREAM PRO V1 2.4G WiFi Bluetooth 5.0 receiver to I2S Multiroom 192kHz
Reference : 14066
55,90 €tax incl.
46,58 € tax excl.
Up2Stream PrO V1
Module WiFi & Bluetooth 5.0 Multiroom Receiver DLNA Airplay - 24bit 192khz
This Up2Stream Pro Module is a wireless receiver (wifi and bluetooth 5.0) to I2S output. It is compatible with spotify, airplay, dlna, internet radio, web streaming, USB key, NAS. It allows you to add a non-wired connectivity to your hi-fi system or active speakers.
The circuit is designed to allow complex integrations as well: multiroom, multizone streaming channel synchronization.
Optimal network connectivity
The module provides complete network connectivity to anticipate every scenario and allow you to make the best choices for best audio quality.
It supports Airplay technology, DLNA, Spotify Connect, Qplay.  It can retrieve an audio stream from a web platform, but also from local files from a phone or a computer.
RJ45 input is available as well for situations where your home network cannot be used. This input provides stable Ethernet access to network even if the wireless router is not good enough.
Bluetooth 5.0
The module supports the Bluetooth 5.0 connection with a very advantageous range up to 30 meters.
The Dual Bluetooth & WiFi connectivity will delight audiophiles DIYer who have disparate or heavily modified facilities: all-time problem of compatibility may be circumvented by passing from one technology to another. Thus, a user wishing to connect to its new platform unavailable streaming audio system over WiFi & application will always run through bluetooth without performing Additional hardware change.
Please note, a user seeking the most accurate audio quality will focus systematically on wifi and the dedicated application to get the best sound reproduction available on this module.
4Stream Application
The essential features of the module can be controlled from a smartphone or tablet via 4STREAM application. The latter allows to easily stream audio from the phone memory and control advanced functions such as multi-room, multi-zone or synchronized platform pairing of multiple speakers / channels.
The application also provides several EQ options, Volume control, playback options...etc
Dimensions
TypeWiFi and Bluetooth receiver
Supported audio formatsFLAC
EPA
WAV
MP3
WMA
AAC
AAC +
ALAC
Sampling rateUp to 96kHz 24bit
ServicesAirplay
DLNA
Spotify Connect
Qplay supported
Spotify
Deezer
Tidal
Qobuz
Napster
iHeartRadio
Internet Radio
Bluetooth5.0
low latency
Stereo syncYes
Power SupplyDC 5V / 1A
Micro-USB / Screw Terminal
Dimensions85 x 50 mm
Package Contents
Module Bluetooth audio receiver Wifix1
4-wire cable NMR 2.54 - 22mmx1
InputJack 3.5mm
InputBNC
InputRJ45
InputWiFi
OutputI2S
Download
