TINYSINE AUDIOB PLUS aptX Bluetooth Receiver Module U.FL
New
This Tinysine AudioB Plus Bluetooth receiver module is based on a Qualcomm QCC3008 chip. This allows it to support sampling rates up to 16bit 48kHz and reliable, stable transmission via the aptX codec. It features a U.FL connector for connecting an external 2.4G antenna. The module has two rows of 10 pins, with a 2mm pitch between pins, for easy integration into many types of DIY projects such as a Bluetooth amplifier or a DAC.
Reference : 22761
13,99 €tax incl.
11,66 € tax excl.
TinySine AudioB Plus Bluetooth 5.0 aptX Receiver Module U.FL
TINYSINE AUDIOB PLUS: Front view
This Bluetooth receiver module Tinysine AudioB Plus is based on a Qualcomm QCC3008 chip. This allows it to support sampling rates up to 16bit 48kHz and reliable, stable transmission via the aptX codec. It features a U.FL connector for connecting an external 2.4G antenna. The module has two rows of 10 pins, with a 2mm pitch between pins, for easy integration into many types of DIY projects such as a Bluetooth amplifier or a DAC.
TINYSINE AUDIOB PLUS: wiring diagram
Technical specifications
Product typeBluetooth receiver module
Bluetooth chipQCC3008
Bluetooth version5.0
Supported sampling rate16bit 48kHz
Supported Bluetooth codecaptX, SBC, AAC
Consumption5mA @ 5V
Supported Bluetooth profilesHFP V1.6
HSP V1.2
A2DP V1.2
AVRCP v1.4
Smartphone app support
Package1x Tinysine AudioB Plus
OutputPH 2.0mm
This Tinysine AudioB Plus Bluetooth receiver module is based on a Qualcomm QCC3008 chip. This allows it to support sampling rates up to 16bit 48kHz...
