TINYSINE TSA3120B PARTY MODE Stereo DSP Amplifier Module DSP Bluetooth 5.1 2x30W
The TINYSINE TSA3120B PARTY MODE is a compact stereo audio amplifier / Bluetooth receiver module designed for DIY projects, custom speakers, multiroom installations, and portable audio systems. It combines efficient digital amplification, Bluetooth connectivity, and an integrated DSP processor, all in a small and easy-to-integrate format. Its key feature is its Party mode, capable of wirelessly linking multiple boards to broadcast music simultaneously across several speakers.
Reference : 21787
44,91 €tax incl.
37,42 € tax excl.
TinySine TSA3120B PARTY MODE Bluetooth 5.1 DSP Stereo Amplifier Module 2x30W
Photo of the TINYSINE TSA3120B PARTY MODE module
The TinySine TSA3120B PARTY MODE is a compact stereo audio amplifier / Bluetooth receiver module designed for DIY projects, custom speakers, multiroom installations, and portable audio systems. It combines efficient digital amplification, Bluetooth connectivity, and an integrated DSP processor, all in a small and easy-to-integrate format. Its key feature is its Party mode, capable of wirelessly linking multiple boards to broadcast music simultaneously across several speakers.
TinySine TSA3120B PARTY MODE: efficient stereo amplification
The TSA3120B delivers up to 2 x 30 watts in stereo thanks to its TAS5756M chip, allowing it to efficiently drive 4Ω or 8Ω passive speakers. Thanks to its Class D architecture, it offers excellent energy efficiency above 90%, reducing heat and power consumption.
This technology makes it an ideal solution for portable speakers, battery-powered systems, or installations where space is limited.
TinySine TSA3120B PARTY MODE: built-in Bluetooth for instant wireless streaming
The board features Bluetooth 5.x connectivity, allowing music to be streamed directly from a smartphone, tablet, or computer without any additional external module. Pairing is quick and easy: simply power the board, search for the device “TSA3120B”, and connect.
It also supports advanced technologies such as Qualcomm TrueWireless and aptX, improving connection stability and audio quality on compatible devices.
TinySine TSA3120B PARTY MODE: multiple synchronized modules
The Party Mode version sets this model apart from standard Bluetooth amplifiers. It allows multiple TSA3120B boards to be wirelessly connected so they all play the same music in perfect sync.
In practice, one board acts as the transmitter (master) and the others as receivers (slave). This setup is particularly useful for:
  • parties and events
  • multiroom installations
  • large indoor or outdoor spaces
  • scalable audio systems
TinySine TSA3120B PARTY MODE: integrated DSP
The TSA3120B features an ADAU1701 DSP processor, a major advantage for audio enthusiasts seeking precise adjustments. Using SigmaStudio software, it becomes possible to deeply customize the sound rendering according to project needs and the characteristics of the speakers used.
Users can adjust bass, midrange, treble, overall gain, configure active filters, set up crossovers, apply delays, or fine-tune advanced equalization. Each adjustment helps achieve a more balanced, dynamic sound perfectly suited to the installation.
This flexibility enables fully customized audio projects with a much higher level of optimization than a standard amplified module.
TinySine TSA3120B PARTY MODE: connectivity and easy integration
The module operates with a 12V to 24V DC power supply, making it compatible with many power adapters or batteries. Its compact size of 105 x 75 x 20 mm makes it easy to integrate into a DIY speaker, audio furniture, or a custom enclosure.
Additional ports also allow connection of:
  • external potentiometers
  • volume controller
  • USBi DSP programmer
  • custom control buttons
It is suitable for both hobbyists and experienced makers.
Overview of the TinySine TSA3120B PARTY MODE
Overview of the TINYSINE TSA3120B PARTY MODE
1Line input
2Line outputs
3DC power input via screw terminal
4DC power input via DC jack
5Amplified stereo outputs on screw terminal
6DSP programming port
7Volume potentiometer port
8BVC port
9I2S output
Technical specifications
Product typeBluetooth amplifier module
Amplifier chipTSA5756M
DSP chipADAU1701
Input1x Line input
Bluetooth
Output1x Amplified output 2x30W on screw terminals
2x Line output
1x I2S output
Supported Bluetooth codecsaptX
Output power2x 28W (THD+N = 0.1%)
Default gain26dB
Minimum load3 ohms
Bluetooth transmission range50-100m
Operating temperature20-50°C
Power supply12-24V DC
Dimensions105x75x20mm
Package contents1x TinySine TSA3120B PARTY MODE
1x Bluetooth antenna
InputPCB Connector
OutputScrew terminals
OutputI2S
OutputPCB Connector
Channel2 (Stereo)
Power (W)30.0
The TINYSINE TSA3120B PARTY MODE is a compact stereo audio amplifier / Bluetooth receiver module designed for DIY projects, custom speakers,...
