Module WiFi & Bluetooth 5.0 Multiroom Receiver DLNA Airplay - 24bit 192khz
This Up2Stream Pro Module is a wireless receiver (wifi and bluetooth 5.0) to I2S output. It is compatible with spotify, airplay, dlna, internet radio, web streaming, USB key, NAS. It allows you to add a non-wired connectivity to your hi-fi system or active speakers.
The circuit is designed to allow complex integrations as well: multiroom, multizone streaming channel synchronization.
The module provides complete network connectivity to anticipate every scenario and allow you to make the best choices for best audio quality.
It supports Airplay technology, DLNA, Spotify Connect, Qplay. It can retrieve an audio stream from a web platform, but also from local files from a phone or a computer.
RJ45 input is available as well for situations where your home network cannot be used. This input provides stable Ethernet access to network even if the wireless router is not good enough.
The module supports the Bluetooth 5.0 connection with a very advantageous range up to 30 meters.
The Dual Bluetooth & WiFi connectivity will delight audiophiles DIYer who have disparate or heavily modified facilities: all-time problem of compatibility may be circumvented by passing from one technology to another. Thus, a user wishing to connect to its new platform unavailable streaming audio system over WiFi & application will always run through bluetooth without performing Additional hardware change.
Please note, a user seeking the most accurate audio quality will focus systematically on wifi and the dedicated application to get the best sound reproduction available on this module.
The essential features of the module can be controlled from a smartphone or tablet via 4STREAM application. The latter allows to easily stream audio from the phone memory and control advanced functions such as multi-room, multi-zone or synchronized platform pairing of multiple speakers / channels.
The application also provides several EQ options, Volume control, playback options...etc
| Specifications | |
| Type | WiFi and Bluetooth receiver |
| Supported audio formats | FLAC EPA WAV MP3 WMA AAC AAC + ALAC |
| Sampling rate | Up to 96kHz 24bit |
| Services | Airplay DLNA Spotify Connect Qplay supported Spotify Deezer Tidal Qobuz Napster iHeartRadio Internet Radio |
| Bluetooth | 5.0 low latency |
| Stereo sync | Yes |
| Power Supply | DC 5V / 1A Micro-USB / Screw Terminal |
| Dimensions | 85 x 50 mm |
| Package Contents | |
| Module Bluetooth audio receiver Wifi | x1 |
| 4-wire cable NMR 2.54 - 22mm | x1 |
