ARYLIC BT10 Bluetooth 5.2 Transmitter
Arylic's BT10 is a Bluetooth transmitter that will modernize your installation by allowing any source to become a connected device. Its 5.2-standard Bluetooth connectivity supports high-definition codecs, aptX HD, aptX Adaptive and aptX Low latency. In terms of connectivity, the BT10 features a 3.5mm jack line input, an optical input, a USB-A input and a 3.5mm jack line output, enabling it to be used as a DAC supporting up to 24bit 194kHz PCM.
Reference : 20204
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 16-07-2025.
Arylic BT10 Bluetooth 5.2 Transmitter aptX HD, aptX Adaptive, aptX Low Latency
Arylic BT10 : Front view
Arylic
 that will modernize your installation by allowing any source to become a connected device. Its Bluetooth 5.2 connectivity supports high-definition codecs, aptX HD, aptX Adaptive and aptX Low latency. In terms of connectivity, the BT10 features a 3.5mm jack line input, an optical input, a USB-A input and a 3.5mm jack line output, enabling it to be used as a DAC supporting up to 24bit 194kHz PCM.
Arylic BT10 : Features summary
Arylic BT10 : Bluetooth 5.2
The BT10 benefits from Qualcomm's Bluetooth 5.2 chip, enabling it to support aptX, aptX HD, aptX Low Latency, aptX Adaptative, AAC and SBC codecs over an unobstructed range of 15m.
Arylic BT10 : Installation example
Arylic BT10 : DAC function
Thanks to its digital inputs and 3.5mm jack line output, the BT10 can act as a DAC supporting sampling rates up to PCM 24bit 192kHz. So you can enjoy CD-quality audio streams, whether wired or wireless.
Arylic BT10 : Wireless stereo system
The BT10 can transmit via Bluetooth to two different devices simultaneously, so you can connect two Bluetooth speakers for a wireless stereo system. Furthermore, thanks to its line output, you can connect a third active speaker, giving you the option of a 2.1 installation.
Arylic BT10 : 2.1 installation
Arylic BT10 : ACPWorkbench
The ACPWorkbench tuning tool lets you customize your audio experience. With this tool, you can adjust the frequency on each channel, adjust channel balance, customize deep EQ settings and much more.
ACPWorkbench software sold separately. You can buy it on Arylic website.
Arylic BT10 : IR remote control
A remote control is also supplied to enable remote control of the BT10 for a comfortable user experience.
Arylic BT10 : Remote control
Arylic BT10 : Go Control app
Arylic BT10 : Go Control application
The Go Control application lets you easily control the BT10 remotely, and access a wide range of settings such as equalization and channel balance, for a personalized sound according to the type of music being played and your tastes.
Arylic BT10 Overview
Arylic BT10 : Schéma
1Short press : Switch mode
Long press : Standby mode on/of
2Short press : Decrease volume
Long press : Play or Pause music
3Short press : Lecture ou pause de la musique
Quickly press twice : Disconnect current Bluetooth connection
4Short press : Increase volume
Long press : Play next track
5LED : Indicate current status and input source
6IR receiver
7Optical input
8Line input
9Line output
10USB-A input
11USB-C input / Power supply
Product typeBluetooth transmitter
Inputs1x Optical
1x USB-C (DAC)
1x USB-A (USB Host)
1x Line input 3.5mm jack
OutputsBluetooth 5.2
1x Line output 3.5mm jack
Supported Bluetooth codecsaptX, aptX HD, aptX Low Latency, aptX Adaptive, AAC, SBC
Supported sampling ratesOptical : PCM 24bit 192kHz
USB-A : 48kHz
USB-C : 48kHz
USB Host compatibilityFormat : FAT16, FAT32, exFAT, up to 128GB
Formats : mp3, mp4, wma, mov, m4a, aac, flac, ape
Bluetooth range15m
Power supply5V/1A (power supply included)
Dimensions108 x 72 x 26.6mm
Weight90g
Package1x Arylic BT10
1x Remote control
1x Power adapter
1x 3.5mm jack to 3.5mm jack cable
1x 3.5mm jack to RCA cable
1x USB-C to USB-C cable
InputJack 3.5mm
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipNC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsSBC
ARYLIC BT10 Bluetooth 5.2 Transmitter aptX HD aptX Adaptive aptX LL
Arylic's BT10 is a Bluetooth transmitter that will modernize your installation by allowing any source to become a connected device. Its...
