Dongle USB 2.0 Bluetooth Audio Transmitter 4.0 aptX
4.3 / 5
Reference : 7201
9,90 €tax incl.
8,25 € tax excl.
Last items in stock !
Shipping date: 16-05-2025.
Here is finally a solution that many of us waited for, this small adapter has the ability thanks to the technology used to wirelessly transfer music streams in CD quality from your PC.
Where does the difference lie? this small adapter adopts under its black shell the best of Bluetooth 4.0 technology with the adoption of the Apt-X codec.
Compatible with all Bluetooth devices AD2P, it offers a reproduction very close to CD-Audio thanks to a low compression ratio. Thus, FLAC, Apple Lossless or PCM audio files are rendered almost perfectly. When files natively in MP3 or AAC (with a rate less than 350Kbits / sec), they are transmitted without decoding and without any degradation.
OfThis small receiver allows you to stream your favorite songs on your Bluetooth compatible audio system.
Specifications:
  • Chipset: CSR BC8510
  • Bluetooth 4.0 + EDR (Retro compatible)
  • Transmission Frequency: 2.402 - 2.48 GHz
  • Range: 10m
  • Data Transfer Rate: 3 Mbps
  • Compatible with USB1.1 / 2.0 / 3.0
  • Low Power Bluetooth
  • Standard: APT-X stereo encoder
  • Type: Class 1 for long distance operations
  • Simplified Pairing
  • Length: 1.9 cm
  • Communicates with any non-A Bluetooth devicePT-X
  • Compatible with Windows XP, Vista, Win7
ATTENTION THE PACKAGE OF THIS PRODUCT CONTAINS A CDROM OF DRIVERS
To date no driver for MacOS is available.
PDF Manufacturer
https://www.audiophonics.fr/images2/6518/6518_ADVANCEWTX500_4.jpg
https://www.audiophonics.fr/images2/7201/7201_DONGLE_BLUETOOTH_APTX_1.jpg
https://www.audiophonics.fr/images2/7201/7201_DONGLE_BLUETOOTH_APTX_2.jpg
OutputBluetooth
OutputUSB
DAC / ADC ChipNC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX
Supported Bluetooth codecsAAC
14 reviews
Pratique !
Un peu de difficultés à installer le pilot, mais maintenant que tout fonctionne c'est parfait.
This review has been posted for Dongle USB 2.0 Bluetooth Audio Transmitter 4.0 aptX
Se désinstalle tout seul
J'ai acheter ce dongle i y a 3mois pour envoyer du son sur un récepteur Arcam rBlink. Impossible de le faire marcher sous Windows 7, avec ou sans cd d'installation. Sur un autre PC sous windows 8, j'ai réussi à le faire marcher sans le cd d'installation puis un beau jour, une fois le pc redémarré, impossible de retrouver mon Arcam rBlink dans la liste des périphériques son. J'ai donc supprimé tout ce qui concernait bluetooth de mon pc pour ensuite réinstaller avec cd, puis sans cd, rien à faire.
Dans le gestionnaire de périphériques, pour le "Generic Bluetooth Adapter" ca me dit que "windows a arrêté ce périphérique car il présente des pb"
Je précise que le problème ne peut pas venir du Arcam car il n'y a aucun problème d'appairage avec mon smartphone ou un MacBook.
Très déçu par ce dongle, ça m'a l'air très compliqué à faire fonctionner.
Indispensable
J'ai acheté ce d'ongle en complément d'un casque Bluetooth momentum de chez sennheiser, l'ensemble fonctionne parfaitement et la diféfence en Bluetooth ou filaire n'est pas audible.
L'aptitude rempli parfaitement son rôle.
Super
Utilisé avec portable sans bluethooth, fonctionne super
Pas mal !
Trouver une clé USB APTX n'est pas aisée et celle-ci fonctionne tres bien.
Avantage : Qualité du son et APTX / Reconnu automatiquement par mon NAS Synology !
Inconvénient : Portée faible / Obligé de passer par le CD d’installation pour les drivers en Windows 7.
Produit reçu en 2 jours : Top !
