FIIO AIR LINK Bluetooth 6.0 Transmitter Black
New
The FiiO AIR LINK is a small, portable, and convenient USB Bluetooth transmitter that allows for simultaneous charging and audio streaming. It features a Qualcomm QCC5181 chip and Bluetooth 6.0 technology, enabling the AIR LINK to provide a stable, fast, and virtually latency-free connection. The AIR LINK features a USB-C input and output, making it easy to charge and use multimedia simultaneously.
Reference : 21655
49,90 €tax incl.
41,58 € tax excl.
FiiO AIR LINK Bluetooth 6.0 Transmitter USB-C QCC5181 aptX Lossless LDAC 24bit 96kHz Black
FiiO AIR LINK
The Bluetooth 6.0 connection supports codecs such as LDAC (24bit 96kHz) and aptX Lossless, delivering highly faithful sound quality that rivals a wired connection. In addition, the connection offers a long, interference-free range of up to 50 meters in open areas and up to 35 meters in obstructed areas.
Le bouton intégré multifonction permet d'accéder facilement à toute les fonctions d'appairage et de déconnexion facilitant la manipulation de l'émetteur et permet également de facilement basculer entre les modes Bluetooth aptX et LDAC. An LED on the transmitter indicates which Bluetooth codec is being used.
FiiO AIR LINK Description
FiiO AIR LINK: Setup via the app or website
Using the dedicated FIIO Control app or the web interface, you can easily configure your device. Quickly and easily switch Bluetooth codecs, update the firmware, and manage your connection to multiple devices.
Les périphériques Android se connectent à l'application via USB. Les périphériques Apple se connectent à l'application via Bluetooth. L'interface web est accessible via connexion USB.
Product typeBluetooth transmitter
ProcessorQualcomm QCC5181
InputsUSB-C female (charging)
USB-C male (Power supply / Data transfer)
OutputBluetooth 6.0
Supported sampling rates24bit 96kHz
Supported Bluetooth codecsLDAC, aptX Adaptive, aptX Lossless, aptX HD, aptX, aptX LL, SBC
Bluetooth transmission distance35m+ with Obstacles
50m+ open space
LED indicatorWhite pulse: LDAC
Green pulse: aptX Adaptive
Red pulse: aptX Lossless
Yellow pulse: aptX HD
Purple pulse: aptX / aptX LL
Blue pulse: SBC
Red and blue light flashing alternately: pairing
Blue flashing: Waiting to reconnect
Supply power5V 1A via USB-C
WeightApproximately 5g
Dimensions34.5 x 23.5 x 9.5mm
Package1x FiiO AIR LINK
1x USB-A to USB-C Adapter
OutputBluetooth
DAC / ADC ChipNC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsaptX Lossless
FIIO AIR LINK Bluetooth 6.0 Transmitter USB-C QCC5181 aptX Lossless LDAC 24bit 96kHz Black
The FiiO AIR LINK is a small, portable, and convenient USB Bluetooth transmitter that allows for simultaneous charging and audio streaming. It...
