IKKO ARC ITB05 Bluetooth 5.0 Receiver Balanced DAC Headphone Amplifier 2x AK4377 CIEM 0.78
The Ikko Arc ITB05 is a combo Bluetooth and DAC receiver / Headset Amplifier symmetrical neckband format, taking advantage of an excellent design quality to promote a high quality sound reproduction. This model has a CIEM 0.78 format connector to connect your headset or earphones. It will thus allow you to broadcast your music directly from your smartphone or tablet to the receiver. This means that there is no need for a cable between your headphones or earphones and your playback device.
Reference : 14626
139,00 €tax incl.
115,83 € tax excl.
Ikko Arc ITB05
Ikko Arc ITB05 Récepteur Bluetooth DAC Amplificateur Casque Symétrique 2x AK4377 MMCX
Balanced Output, Dual AK4377 DAC
The conversion and amplification stage of the ITB05 is based on a pair of independent AKM AK4377 DAC chips, each managing one channel for a fully balanced output. This architecture allows for high quality sound reproduction that is both accurate and transparent, with a significant reduction in noise.
Extremely stable Bluetooth reception
Bluetooth 5.0 reception is provided by a Qualcomm QCC3034 chip, ensuring high signal stability. In addition, the QCC3034 is compatible with the standard Bluetooth codecs SBC and AAC, as well as with the aptX and aptX-HD, enabling high quality transmission without delay, up to 24bit 48kHz for the aptX HD.
Product typeBluetooth receiver
DAC
Headphone amplifier
DAC / Amplifier chipAKM AK4377
SNR120dB
THD+N0.001%
Bluetooth version5.0
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD
Bluetooth profilesHSP/HFP, A2DP, AVRCP Spp, PBAP
Bluetooth distance10m
ConnectorsCIEM 0.78
Charging connectorUSB-C
Charging time2h
Battery life9h
OutputCIEM 0.78
DAC / ADC ChipAK4377
The Ikko Arc ITB05 is a combo Bluetooth and DAC receiver / Headset Amplifier symmetrical neckband format, taking advantage of an excellent design...
