Using a set of 7 wires twisted then varnished, this type of coil has a larger wire surface compared to a single-stranded conductor. This technique gives a better conductivity in the high frequencies (skin effect) and a reduced noise (varnish).
Copper coil 7 strands 2.7mH
| Specifications | |
| Product type | Coil |
| Inductance | 2.7mH |
| Resistance | 0.52Ω |
| Conductor material | Copper |
| Conductors | Varnished Litz wires, 7x0.6mm |
| Section | 1.98mm² |
| Wire diameter | Ø1.9mm |
| Tolerance | Max : 3% Typ : 1.5% |
| Former material | Fiberglass reinforced PA |
| Dimensions | Ø70 x 59mm |
