JANTZEN AUDIO C-COIL 4N 000-6317 Copper 12AWG Ø2mm 6mH 0.07 Ohm
Reference : 11415
100,20 €tax incl.
83,50 € tax excl.
Shipping date: 11-09-2026.
Jantzen Audio toroidal coil / C-Coil
Low filter coil
Jantzen Audio's C-Coil Toroidal Coils have very low electric resistance and excellent heat tolerance. They can thus withstand high power without overheat-induced distorsion. This model can handle up to 2500W (RMS) / 8Ω . Because of this, Jantzen C-Coil make great inductors for passive filtering low-frequencies crossover.
Caution, due to the electromagnetic field inherent to their construction, C-Coils coils are not suitable for a crossover rising above 1.20kHz. Similarly, they are not intended for amplification or other active system.
Each coil is individually tested with the measurement system CLIO @ 1kHz AC 1V.
TypeETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
MaterialsCopper ETP Standard C11000 / Certified IACS
CoreEpoxy laminated steel plates
Inductance6,0mH +/-5%
Power Handling (RMS)2500W (RMS) / 8Ω
RDC0.07 Ohm
Coil External Diameter106mm
Coil Height37mm
Coil Internal Diameter40mm +/-3
Wire Diameter2,00mm⌀
AWG12
Weight1,240kg
Inductance (mh)6.0
