Section (mm²)
0 mm - 15 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Frédéric A.
Excellent mais...
Ce câble offre une balance tonale équilibrée. Mais associé à l'amplificateur Audio-gd Master-3, il manque de présence dans...
Hans V.
Perfect passend voor infinity Kappa
Gezien de Infinity Kappa op de achterzijde in originele bezetting maar hele korte terminal pluggen kan gebruiken ben ik op deze...
Krzysztof K.
Incredible DAC!
OK, cons first:
1/ clicking sound on digital coax cable connection when you switch from one sample rate material to another...
Bulk Cables
  • Speaker Cables
    Speaker Cables
    Find here all our cables for speakers and loudspeakers, sold by the meter, cut, allowing the design of your own finished cables.
  • Interconnect Cables
    Interconnect Cables
    Find here all our modulation cables, sold by meter, cut, allowing the design of your own finished cables.
  • Digital Cables
    Digital Cables
    Find here all our digital cables, sold by the meter, cut, allowing the design of your own finished cables.
  • Power Cables
    Power Cables
    Find here all our power cables, sold by the meter, cut, allowing the design of your own finished cables.
  • Hook-up Wires
    Hook-up Wires
    Find here all our wiring wires, sold by the meter, to cut, allowing the internal wiring of your devices and DIY projects.
  • Silver Gold Copper Wires
    Silver wire, OCC wire
  • Wiring Accessories
    Wiring Accessories
