NEOTECH NEP-3002G Power Cable
Neotech NEP-3002G is a mains cable made up of 3 multi-stranded conductors in G-UPOCC copper, a combination of OCC copper and graphene, with a total cross-section of 4.17mm² (11AWG) and a diameter of Ø15mm. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
Reference : 19920
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 26-08-2026.
Câble vendu au mètre
Neotech NEP-3002G Power Cable Graphene Copper G-UPOCC 4.17mm² Ø15mm
Neotech NEP-3002G : Front view
Neotech NEP-3002G is a power cable made up of three multi-stranded conductors in G-UPOCC copper, a combination of OCC copper and graphene, with a total cross-section of 4.17mm² (11AWG) and a diameter of Ø15mm. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
This top-of-the-range cable features PVC LC3 insulation, cotton fibre and a PVC outer jacket. A double shield made of Al-Mylar aluminium and tinned OFC braided copper foil also effectively protects this cable from EMI/RFI interference. This cable is ideally suited to the manufacture of mains power cables for Hi-Fi products requiring powerful, clean power.
Product typePower cable
Number of conductors3
Cross-section4.17mm² (11AWG)
Total cable diameterØ15mm
Conductive materialGraphene copper G-UPOCC
Insulation materialsPVC CL3 + Cotton fiber
ShieldingAluminium Al Mylar
Tinned OFC copper foil
Sheath materialPVC
ColorGrey
PackageSold by the meter
Diameter (mm)15.0
Insulation materialPVC
Insulation materialCotton
ShieldingYes
Section (mm²)4.17
Conductors material (Cable)Graphene
Ground / ShieldingYes
Du dépit...au plaisir d'écoute
Après avoir acheté le petit frère en 2,5mm, j'ai tenté ce diamètre pour alimenter ma source car le fréro entre mur et barrette avait été superbe d'entrée de jeu... totalement séduit.
L'ajout d'un 2ème cordon Néotech graphène sur mon lecteur m'a entrainé dans une période de rodage particulièrement désagréable. Ca a saigné dur et ça a été la valse des prises pour rendre l'écoute acceptable car beaucoup trop d'aigu (comme si on avait rajouté 4 prises rhodium au système), sonorité métallique, effacement du grave, manque de profondeur par contre rapidité et gain en transparence/ouverture évident. Il a vraiment fallu que je me raisonne pour ne pas mettre ce nouveau cordon au rebut. Après 80H00 c'était un tout petit poil mieux mais je doutais encore de pouvoir garder ce cordon. J'ai donc agit un peu sur mon traitement acoustique et mis en commande une nouvelle prise schuko ETI legato avec une amélioration dès la mise en place.
Après plus de 250H00 (il me semble un peu en dent de scie) les choses sont revenues à la normale avec un retour du grave et des aigus non montants, de la profondeur et toujours cette superbe ouverture/rapidité/placement/matière. Les voix sont magnifiées (plus de lisibilité). Dans mon salon "cathédrale" sur les enregistrements adéquats la scène sonore par loin derrière, monte à 7,50, et, si enregistré ainsi, passe derrière mes oreilles niveau ouverture. On tape du pied du début à la fin... C'est vraiment du tout bon. Peut-être un très léger manque de musicalité, à voir dans le temps... Pour info si ça peut donner des idées :(enceintes Thiel CS 3.7) blocs monos Aesthétix, en direct du tableau avec câble Tornado Audio + IEC Iégo cuivre/or 8085, Mur/barette, Néotech graphène en 2,5 schuko ETI legato + IEC oyade C004, barette/ source câble Neotech graphène en 4 mm schuko ETI legato + Viborg cuivre/argent/rhodhium, barette/préampli câble Furutech FP 3 TS 762 schuko ETI legato + IEC oyade C004.
Je répète, quelque soit le système les prises ont aussi beaucoup d'importance. Je vais tenter prochainement l'introduction d'une IEC Viborg full argent. Musicalement
 (4)
This review has been posted for NEOTECH NEP-3002G Power Cable Graphene Copper G-UPOCC 4.17mm² Ø15mm
Neotech NEP-3002G is a mains cable made up of 3 multi-stranded conductors in G-UPOCC copper, a combination of OCC copper and graphene, with a total...
