NEOTECH NEP-3200G Power Cable
Neotech's NEP range consists of high-end power cables using only the purest UP-OCC copper conductors. The NEP-3200G is no exception, with 16 Graphene + UP-OCC Copper conductors with a total cross-section of 9AWG (6.63mm²).
By buying this product you get 26 loyalty points
Reference : 20215
269,00 €tax incl.
224,17 € tax excl.
Shipping date: 07-04-2026.
Câble vendu au mètre
Neotech NEP-3200G Power Cable UP-OCC Copper 6.63mm² Ø15.6mm
Photo of Neotech NEP-3200G cable
Neotech's NEP range consists of high-end power cables using only the purest UP-OCC copper conductors. The NEP-3200G is no exception, with 16 Graphene + UP-OCC Copper conductors with a total cross-section of 9AWG (6.63mm²). The 16 17AWG (1.5mm diameter) conductors are individually sheathed, insulated and shielded with PTFE and Mylar-Aluminium.
This cable is particularly effective for high-current amplifiers, power strips or line conditioners. This cable, sold by the meter, will enable you to design very high-quality power cables, and is also perfectly suited to carrying high currents for demanding HiFi systems. In addition, the excellent transmission quality of the electrical signal enables these cables to deliver excellent sound reproduction with enhanced dynamics.
G-UPOCC conductivityOCC and UP-OCC comparison
Product typePower cable
Number of conductors16
Conductor materialG-UPOCC copper (Graphene + UPOCC)
Conductor cross-section9AWG (6.63mm²)
External diameterØ15.6mm
InsulationTeflon + Mylar- Aluminum
External sheatPVC
ColorNight blue
PackageSold by meter
Diameter (mm)15.6
Insulation materialAl-Mylar
Insulation materialPTFE
Insulation materialPVC
ShieldingYes
Section (mm²)6.63
Conductors material (Cable)Graphene
Ground / ShieldingYes
Tres bon cable sur mon (gros) integre
J'ai demande a Audiophonics de realiser une cable secteur sur mesure a partir de ce cable et de connecteurs NEOTECH NC-P313RH et NEOTECH NC-P303II.
La realisation en est tres soignee.
Ce cable a un seul defaut, il est tres raide donc ne soyez pas trop juste sur la longueur.
Je l'utilise sur un integre PASS LABS INT-60 qui a une tres grosse alimentation lineaire (Transfo de 1000VA).
Apres environ 500 heures d'ecoute, le resultat est tres positif.
Cet ampli est un tout petit peu trop riche et le cable a netoye legerement l'ecoute tout en gardant un chatoiement delicieux.
Les basses sont propres mais gardent un bonne densite. La scene sonore est large et profonde mais precise.
La dynamique est la.
Les voix et les instruments ont de la matiere.
Les timbres sont realistes.
C'est un cable tres equilibre et qui ne bride pas de grosses alimentations.
This review has been posted for NEOTECH NEP-3200G Power Cable G-UPOCC Copper 6.63mm² Ø15.6mm
Neotech's NEP range consists of high-end power cables using only the purest UP-OCC copper conductors. The NEP-3200G is no exception, with 16...
