OLFLEX CLASSIC 100 Power cable 3x0.75mm Ø 5.7mm
Reference : 8585
0,95 €tax incl.
0,79 € tax excl.
High electrical performance thanks to its 4kV test voltage.
Great flexibility thanks to the layers of conductors.
Characteristics :
  • Up to 1.5 mm²: Rated voltage U0 / U: 300/500 V
  • Starting at 2.5 mm²: Rated voltage U0 / U: 450/750 V
  • Conductor cross-section up to 185 mm²
  • External Diameter: 5.7mm
  • Copper rating kg: 21.6
  • Specific flow resistance insulation:> 20 GOhm x cm
  • Design of the core: Fine strands according to VDE 0295, Class 5 / IEC 60228 class 5
  • Minimum bending radius:
    • Occasionally movable: 15 x outside diameter
    • Fixed: 4 x outside diameter
  • Nominal voltage:
    • Up to 1.5 mm²: U₀ / U: 300/500 V
    • Starting from 2.5 mm²: U₀ / U: 450/750 V
    • From 2.5 mm² in fixed and protected installation: U₀ / U: 600 / 1000V
  • Test voltage: 4000 V
  • Protective conductor:
    • G = with protective conductor ve / ja
    • X = without protective conductor
  • Temperature range:
    • Occasionally mobile: -5 ° C to + 70 ° C
    • Fixed installation: -40 ° C to + 80 ° C
Applications:
  • Industrial engineering, Mechanical engineering, Heating and air conditioning, Power stations
  • In dry or wet rooms with medium mechanical loads
  • For fixed installation or occasionally mobile use without guidance and not subjected to tensile load
  • Designed for torsional applications, typical in wind turbines
Model:
  • Fine copper strands
  • PVC special insulation Lapp P8 / 1
  • Layer Assembly
  • Sheath: PVC, gray
  • Approvals / standards references
  • According to IEC 60227-5 and EN 50525-2-51
Specials:/ Strong>
  • Non-propagating according to IEC 60332-1-2
  • Good chemical resistance
https://www.audiophonics.fr/images2/8585/8585_lappkabel_secteur_olflex100_1.jpg
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingNo
Section (mm²)0.75
ConnectorN/A
