AUDIO BASTION CORNERSTONE BOOSTER II AB-CS-III Cable Support 37-50mm
The Cornerstone II AB-CS-III from Audio Bastion is a cable support designed to limit the pressure exerted by the weight of cables on connectors. Allowing cables to be elevated, this support is made of aluminum for the body, the threaded part is in stainless steel and the top of the support is in silicone. It is possible to weight the support by adding sand inside.
Reference : 22113
79,99 €tax incl.
66,66 € tax excl.
Audio Bastion Cornerstone II AB-CS-III Cable support 37-50mm
Thumbnail of the Cornerstone II AB-CS-II supports
Technical specifications
Product typeCable supports
Height37-50mm
ColorBlack and grey
PackagingSold individually
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
The Cornerstone II AB-CS-III from Audio Bastion is a cable support designed to limit the pressure exerted by the weight of cables on connectors....
